Most Unix workstations allow you to define a ram-disk. If you have enough
RAM you can copy your location to the ram-disk and then run grass normally.Jim Hinthorne Voice: 509-963-2826
Ram-disk? ... Unix?
I'm sorry. I've only been playing on Unix since about 1983, a short
timer, and *do not* claim to be a guru, but I have never heard of
such a thing as "ram-disk" mentioned in the same breath as Unix.I know there are a few new things out there, but this one does not
make any sense to me. Unix does a lot of things with available ram
and stacks up a lot of disk I/O in memory, but ... .Did we mistype DOS?
This is rubbish: exactly the kind of half-witted mis-information which gives
newsgroups a bad name.
Some (if not all) unices DO in fact allow 'ram-disks' or whatever you want to
call it. Slakware LINUX, for example, relies on this feature in order to instal
l
itself. In case any true unix anoraks want to know how to do it, you mount
it like any other disk with an entry in /etc/fstab something like this:
# device directory type options freq pass
/dev/ramdisk /ramdisk ext2 defaults
to find out if your flavour of UNIX can do this, check to see if the device
driver /dev/ramdisk (or something like it) exists. If it does then you can.
Of course you DO need to be root in order to mount a partition, so this
might not be the correct solution to the original question ...
David Wheatley
Department of Archaeology
University of Southampton
Southampton
SO17 1BJ
