In the new r.mapcalc (4.2) there is a row() and col() function. So, one can
create new maps for each (i.e. a map of every cells row number and another of
every cells column number) and querry them directly, or use them in further
r.mapcalc operations.
GOod Luck.
-Eric
Eric Lambert
ENE Division OR GIS Labratory/Geography
P.O. Box 9005 318 Davenport Hall
Champaign, IL 61826-9005 Urbana, IL 61801
E-mail:lambert@gis.uiuc.edu Lab#: (217) 333-5919
WWW: http://ice.gis.uiuc.edu/LAESA/lambert/lambert.html
<> Greetings,
<> Can somebody please tell me if there is a way to identify the file
<> coordinates (i.e. row, col) of a raster map by using the mouse (or any
<> other means) to click on a point in the display. d.what.rast appears to
<> return only the geographic or projection coordinates, but not the file
<> coordinates. Similarly, can a cell be isolated (described or identified)
<> by manually entering the file (or map) coordinates?
<> I am at a loss! All help appreciated.
<> Steve King
<> Hydrologist 10159 East 11th St., Suite 300
<> NOAA, National Weather Service Tulsa, Oklahoma 74128-
3050
<> Arkansas-Red Basin River Forecast Center Off: (918)832-4109
<> sbk@awips1.abrfc.noaa.gov FAX: (918)832-4101
