I have rasterized a vector map, using v.to.rast. As a result of
this I got some holes in my map inherent due to faulty digitizing. How can
I remove these holes. The map is actually a basins map.
Nalneesh Gaur, River Forecast Center, TULSA
Nalneesh Gaur (ngaur@apwk01g3.abrfc.noaa.gov) writes on 14 Feb 94:
you might try a sort of restricted median filter. That is, only
apply the filter if the pixel being examined is zero. This can
be done with r.mapcalc.
