Fix OLD_T_NEW after v.in.dxf
Patches from geni.knu.ac.kr:
Fixed OLD_T_NEW errors with d.vect and related programs after v.in.dxf.
This is not d.vect bug. v.in.dxf puts header info at the wrong location.
ftp://geni.knu.ac.kr/pub/geni/patch/grass/grass5.0beta8-CVS/patch.rt3.gz
README.rt3
1. v.in.ascii misread DIGIT DATE info.
  DIGIT DATE: Thu Jun 1 23:19:39 2000
   G_rindex(buff,':') locate ptr here ^, this means DIGIT DATE is "39 2000".
   Instead, G_index(buff,':') locate ptr
   now DIGIT DATE has correct value "Thu Jun 1 23:19:39 2000".
   This helps with other info including ':'.
2. d.vect and related programs cause OLD_T_NEW errors. This is because
   v.in.dxf and v.in.dxf2 creates broken vector files with wrong header.
   In case fp is opened using G_fopen_append, fseek(fp,0L,0) points EOF.
   So, if file is already opened for adding geo info, fp should be closed
   and reopened using G_fopen_modify.
   Is this only problem of FreeBSD?
Huidae Cho
