Mary Daum writes:
To global-scale GRASS users, a question:
I want to define a region in the western Pacific Ocean. The western
boundary runs through Indonesia (about 110 deg. E); the eastern
boundary just captures Hawaii (about 160 deg. W). When I define
a new mapset with these boundaries, GRASS is happy to accept them,
but when the map is displayed, Hawaii is lurking in the upper LEFT
corner and Indonesia, the Philippines (etc) are crowded into the
RIGHT side of the map, with a big blank area in between. If it
matters, the map is vector lat/long, imported by v.in.arc.Any good ideas out there about how to get Hawaii in the east and
the Asian islands in the west?
Thanks -- Mary
Now I'm not sure she's describing the same problem we've had here,
but for what it's worth: Grass expects (some of) its import files
to have an y/x format instead of x/y (e.g. v.in.ascii). If your yet-
to-be-imported file has a x/y format (or an E/N format), grass will
misinterpret the axes and mirror flip the map...
If this proves to be the bug, you can easily deal with it by using
a simple editing command to have the two coordinate fields change
places.
Martijn van Leusen
