Floating pnt upgrade on SGI - recompile trouble
Hi, I'm trying to compile the floating point upgrade on our SGI Indigo2
(R4400 chipset). When I ran GISGEN it got as far as front.end and died.
Olga kindly provided part of the solution--that the gis library was not
recompiling. I removed all the .o files in src/libes/gis and recompiled with
gmake4.1. Resuming GISGEN got me as far as d.display. I then recompiled
everything in the src/libes/* directories but GISGEN still falls down at
d.points, unable to resolve 'region'.
Can anybody suggest what to do next?
Cheers, and thanks,
Peter Briggs
CSIRO Centre for Environmental Mechanics
GPO Box 821, Canberra, ACT 2601, Australia
ph: +61 6 246 5554 fax: +61 6 246 5560
email: pbriggs@enmech.csiro.au
http://www.enmech.csiro.au/pyelab/people/pbcv.htm
In info.grass.user you write:
Cheers, and thanks,
Peter Briggs
Hi!
Maybe you just don't have the correct libes/gis/sites.c file
(I noticed it was missing from the tar file)
Please substitute your libes/gis/sites.c with the included file.
Sorry for the delayed reply!
Olga
#pragma ident "$Id: sites.c,v 1.39 1995/08/17 21:03:29 mccauley Exp mccauley
* These functions and definitions support the site format for 4.2
* (format proposed by Dave Gerdes):
* easting|northing|[z|[d4|]...][#category_int] [ [@attr_text OR %flt] ... ]
* to allow multidimensions (everything preceding the last '|') and any
* number of text or numeric attribute fields.
* Author: James Darrell McCauley <mccauley@ecn.purdue.edu>
* 31 Jan 1994
* $Log: sites.c,v $
* Revision 1.39 1995/08/17 21:03:29 mccauley
* fixed bug related to time to stime conversion
* Revision 1.38 1995/07/25 15:14:45 mccauley
* fixed error for cat in G_site_describe
* Revision 1.37 1995/07/17 20:55:48 mccauley
* change G_strchr to G_strstr
* Revision 1.36 1995/07/17 11:14:43 mccauley
* took out has_cat and made part of struct
* support for floating point categories
* Revision 1.35 1995/07/14 14:04:14 mccauley
* renamed G_site_get_fmt to G_site_describe
* Revision 1.34 1995/07/14 11:39:49 mccauley
* changed G_site_destroy_struct to G_site_free_struct
* Revision 1.33 1995/07/13 19:58:28 mccauley
* added G_site_destroy_struct
* Revision 1.32 1995/07/05 12:55:40 mccauley
* added warning flags for old API usage
* Revision 1.31 1995/07/05 12:25:48 mccauley
* modified G_site_put to use (Site *) instead of (Site)
* Revision 1.30 1995/07/05 12:07:17 mccauley
* removed extra spaces in G_site_puts output
* Revision 1.29 1995/07/05 12:02:48 mccauley
* added G_site_puts (analog to sprintf for G_site_put)
* Revision 1.28 1995/07/05 12:01:20 mccauley
* fixed bug in G_sites_get_fmt
* Revision 1.27 1995/06/29 16:27:00 mccauley
* fixed malloc error in G_site_new_struct.
* Revision 1.26 1995/06/29 12:08:25 mccauley
* added G_site_in_region.
* Revision 1.25 1995/06/20 16:08:24 mccauley
* first version put in 4.2 release
* Revision 1.24 1995/05/24 00:36:27 mccauley
* added old functions for bc while porting
* Revision 1.23 1995/05/24 00:05:31 mccauley
* added DateTime stuff
* Revision 1.22 1995/04/17 22:56:59 mccauley
* added G_site_put_hdr/G_site_get_hdr. Header records include
* "name|", "desc|", "labels|", and "time|".
* Revision 1.21 1995/02/22 03:23:19 mccauley
* more ctype-like changes.
* Revision 1.20 1995/02/22 03:14:23 mccauley
* changed conditionals to use ctype-like defines (e.g., ispipe).
* Revision 1.19 1995/02/22 02:53:48 mccauley
* skip over header lines in G_site_get and G_site_get_fmt.
* Revision 1.18 1995/02/22 02:45:54 mccauley
* added sites functions from 4.1 that we'll keep.
* Revision 1.17 1995/02/22 02:25:03 mccauley
* changed names of functions to G_site_xxx().
* Revision 1.16 1995/02/21 07:53:48 mccauley
* changed "static char sites_api_rcsid" to pragma ident.
* added function declarations for those int functions that
* should be defined in gis.h. fixed pointer-int comparison
* in next_att().
* No warnings (from this code) for "gcc -Wall."
* Revision 1.15 1995/02/21 07:27:32 mccauley
* added qsort comparison functions.
* still need to re-write G_guess_site_fmt to reflect changes in
* G_new_get_site.
* Revision 1.14 1995/02/21 07:21:49 mccauley
* replaced repititive code with next_att()
* removed erroneous comments. ran indent.
* Revision 1.13 1995/02/21 02:33:14 mccauley
* changes to ignore superflous spaces not contained within quotes.
* changes to use ctyle functions and to do selective reads.
* Revision 1.12 1995/02/18 22:34:37 mccauley
* a few changes to read selective fields (according to what
* was allocated for).
* Revision 1.11 1995/02/09 02:49:20 mccauley
* Added check for dim_alloc in G_new_get_site.
* Removed erroneous check in G_new_put_site.
* Still have error in selective reads.
* Revision 1.10 1995/02/09 00:07:03 mccauley
* Debugged G_guess_site_fmt and ran indent.
* Still need to rewrite G_guess_site_fmt and G_new_get_site so
* that we don't have multiple exits points (too many 'return 0's).
* Revision 1.9 1995/02/08 23:12:20 mccauley
* Added first version of G_guess_site_fmt (untested).
* Revision 1.8 1995/02/08 01:26:27 mccauley
* Changed return vals of G_new_get_site for easier diagnostics.
* For category and decimal attributes, on possible reason for a
* non zero return value is the value does not immediately follow
* the attribute tag (# or %). E.g., "# 2" or "% 23.4" will cause
* an error. Remember to put this in programmers' docs!
* Revision 1.7 1995/02/08 00:54:49 mccauley
* Added a few more checks. Fixed a bug in cleanse_string.
* Revision 1.6 1995/02/08 00:06:24 mccauley
* Added a few checks, combined a few, and changed do/while to while after #.
* Revision 1.5 1995/02/07 23:33:07 mccauley
* fixed bug with G_new_put_site [.dim_alloc already decremented by 2]
* Revision 1.4 1995/02/07 23:24:06 mccauley
* added comments and ran 'indent'
* Revision 1.3 1995/02/07 23:16:04 mccauley
* if length of string attribute is zero, it is not printed. if there
* are no non-zero string attributes, no string attributes are printed.
* Revision 1.2 1995/02/07 21:15:13 mccauley
* recompiled with 'gcc -Wall' and got rid of "unused var" warnings.
* added return values to some functions.
* Revision 1.1 1995/02/07 21:01:12 mccauley Initial revision
#include "gis.h"
#include <ctype.h>
#include <string.h>
#define DQUOTE '"'
#define SPACE ' '
#define BSLASH 92
#define PIPE '|'
#define ispipe(c) (c==PIPE)
#define isnull(c) (c==(char)NULL)
#define isquote(c) (c==DQUOTE)
void G_site_free_struct (s)
  Site *s;
/* Free memory for a Site struct */
  if(s->dim_alloc)
      free(s->dim);
  if(s->str_alloc)
      free(s->str_att);
  if(s->dbl_alloc)
      free(s->dbl_att);
  free(s);
Site *G_site_new_struct (cattype, n_dim, n_s_att, n_d_att)
  RASTER_MAP_TYPE cattype;
  int n_dim, n_s_att, n_d_att;
/* Allocate memory for a Site struct. Returns a properly allocated
   site struct or NULL on error.
   cattype= -1 (no cat), CELL_TYPE, FCELL_TYPE, or DCELL_TYPE
  int i;
  Site *s;
  if (n_dim < 2 || n_s_att < 0 || n_d_att < 0)
    fprintf (stderr, "PROGRAMMER ERROR: invalid # dims or fields in %s\n",
             "G_site_new_struct");
    exit (-1);
  if ((s = (Site *) G_malloc (sizeof (Site))) == NULL)
    return (Site *) NULL;
  s->cattype=cattype;
  s->ccat=s->fcat=s->dcat=0;
  if (n_dim > 2)
    if ((s->dim =
         (double *) G_malloc ((n_dim - 2) * sizeof (double))) == NULL)
  s->dim_alloc = n_dim - 2;
  if (n_d_att > 0)
    if ((s->dbl_att =
         (double *) G_malloc (n_d_att * sizeof (double))) == NULL)
  s->dbl_alloc = n_d_att;
  if (n_s_att > 0)
    if ((s->str_att =
         (char **) G_malloc (n_s_att * sizeof (char *))) == NULL)
    else
      for (i = 0; i < n_s_att; ++i)
        if ((s->str_att[i] =
          (char *) G_malloc (MAX_SITE_STRING * sizeof (char))) == NULL)
  s->str_alloc = n_s_att;
  return s;
int G_site_get (ptr, s)
  FILE *ptr;
  Site *s;
* Reads ptr and returns 0 on success,
* -1 on EOF,
  int cleanse_string ();
  char sbuf[MAX_SITE_LEN], *buf;
  char ebuf[128], nbuf[128];
  char *next_att ();
  int G_projection(), G_scan_northing(), G_scan_easting();
  int n = 0, d = 0, c = 0, dim = 0, err;
  buf = sbuf;
  if ((buf = fgets (sbuf, 1024, ptr)) == (char *) NULL)
    return EOF;
  while (*buf == '#' || !isdigit(*buf) )
      return EOF;
  while ((*buf == '#' || !isdigit(*buf)) && *buf != '-' && *buf != '+')
      return EOF;
  if (buf[strlen (buf) - 1] == '\n')
    buf[strlen (buf) - 1] = (char) NULL;
  if ((err = sscanf (buf, "%[^|]|%[^|]|%*[^\n]", ebuf, nbuf)) < 2)
    fprintf (stderr, "ERROR: ebuf %s nbuf %s\n", ebuf, nbuf);
    return -2;
  if (!G_scan_northing (nbuf, &(s->north), G_projection ()) ||
      !G_scan_easting (ebuf, &(s->east), G_projection ()))
    return -2;
  /* move pointer past easting and northing fields */
  while (!ispipe(*buf) && !isnull(*buf))
    buf++;
  if ( !isnull(*buf) && !isnull(*(buf + 1)))
    buf++;
  else
    return -2;
    buf++;
    buf++;
  else
    return 0;
  /* check for remaining dimensional fields */
  while (G_index (buf, PIPE) != (char) NULL)
    if (dim < s->dim_alloc)
      if ((err = sscanf (buf, "%lf|", &(s->dim[dim++]))) < 1)
        return -2;
    else
        buf++;
      if (isnull(*buf))
        return 0;
      if (!isnull(*(buf + 1)))
        buf++;
      else
        return -2;
  /* no more dimensions-now we parse attribute fields */
  while (!isnull(*buf))
    switch (*buf)
    case '#': /* category field */
      if (n == 0)
        switch(s->cattype)
          case CELL_TYPE:
          if(sscanf (buf, "#%d", &s->ccat)==1)
            n++;
          break;
          case FCELL_TYPE:
          if(sscanf (buf, "#%f", &s->fcat)==1)
            n++;
          break;
          case DCELL_TYPE:
          if(sscanf (buf, "#%lf", &s->dcat)==1)
            n++;
          break;
      else
        sscanf (buf, "#%d", &err);
      /* move to beginning of next attribute */
      if ((buf = next_att (buf)) == (char *) NULL)
        return 0;
      break;
    case '%': /* decimal attribute */
       * if (d >= s->dbl_alloc) return -4;
      if (d < s->dbl_alloc)
        if ((err = sscanf (buf, "%%%lf", &(s->dbl_att[d++]))) < 1)
          return -4;
        return 0;
      break;
    case '@': /* string attribute */
      if (isnull(*buf) || isnull(*(buf + 1)))
        return 0;
      else
        buf++;
    default: /* defaults to string attribute */
      /* allow both prefixed and unprefixed strings */
      if (c < s->str_alloc)
        if ((err = cleanse_string (buf)) > 0)
          G_strncpy (s->str_att[c++], buf, err);
          buf += err;
        else
          return err;
        return 0;
      break;
return 0;
int G_site_put (fptr, s)
  FILE *fptr;
  Site *s;
/* Writes a site to file open on fptr. */
  char ebuf[MAX_SITE_STRING], nbuf[MAX_SITE_STRING];
  char xbuf[MAX_SITE_STRING], buf[MAX_SITE_LEN];
  static int format_double ();
  int fmt, i, j, k;
  int G_format_northing(), G_format_easting(), G_projection();
  fmt = G_projection ();
  G_format_northing (s->north, nbuf, fmt);
  G_format_easting (s->east, ebuf, fmt);
  sprintf (buf, "%s|%s|", ebuf, nbuf);
  for (i = 0; i < s->dim_alloc; ++i)
    format_double (s->dim[i], nbuf);
    sprintf (xbuf, "%s|", nbuf);
    G_strcat (buf, xbuf);
  switch(s->cattype)
    case CELL_TYPE:
    sprintf (xbuf, "#%d ", s->ccat);
    break;
    case FCELL_TYPE:
    sprintf (xbuf, "#%g ", s->fcat);
    break;
    case DCELL_TYPE:
    sprintf (xbuf, "#%g ", s->dcat);
    break;
  for (i = 0; i < s->dbl_alloc; ++i)
    format_double (s->dbl_att[i], nbuf);
    sprintf (xbuf, "%%%s ", nbuf);
  for (i = 0; i < s->str_alloc; ++i)
    if (strlen (s->str_att[i]) != 0)
      /* escape double quotes */
      j = k = 0;
      if (G_index (s->str_att[i], DQUOTE) != (char *) NULL)
        while (!isnull(s->str_att[i][j]))
          if (isquote(s->str_att[i][j]))
            xbuf[k++] = BSLASH;
            xbuf[k++] = DQUOTE;
          else
            xbuf[k++] = s->str_att[i][j];
          j++;
        xbuf[k] = (char) NULL;
      else
        G_strcpy (xbuf, s->str_att[i]);
      G_strcpy (s->str_att[i], xbuf);
      if (G_index (s->str_att[i], SPACE) != (char *) NULL)
        sprintf (xbuf, "@\"%s\" ", s->str_att[i]);
      else
        sprintf (xbuf, "@%s ", s->str_att[i]);
  fprintf (fptr, "%s\n", buf);
  return 0;
int G_site_describe (ptr, dims, cat, strs, dbls)
  FILE *ptr;
  int *dims, *cat, *strs, *dbls;
* Tries to guess the format of a sites list (the dimensionality,
* the presence/type of a category, and the number of string and decimal
* attributes) by reading the first record in the file.
* -1 on EOF,
* -2 for other error.
  int err;
  int itmp;
  float ftmp;
  if (ftell (ptr) != 0L)
    fprintf (stderr, "\nPROGRAMMER ERROR: G_site_get_fmt() must be called\n");
    fprintf (stderr, " immediately after G_fopen_sites_old()\n");
    return -2;
  *dims = *strs = *dbls = 0;
  *cat = -1;
  buf = sbuf;
    rewind (ptr);
    return EOF;
  /* skip over comment & header lines */
      rewind (ptr);
      return EOF;
    rewind (ptr);
    return -2;
  *dims = 2;
    buf++;
  if (!isnull(*buf) && !isnull(*(buf + 1)))
    buf++;
  else
    rewind (ptr);
    return -2;
    buf++;
    buf++;
  else
    rewind (ptr);
    return 0;
    (*dims)++;
      buf++;
    if (isnull(*buf))
      rewind (ptr);
      return 0;
      buf++;
    else
      rewind (ptr);
      return -2;
    switch (*buf)
      sscanf(buf,"#%s ",ebuf);
      if(G_strstr(ebuf,".")==NULL && sscanf(ebuf,"%d", &itmp) ==1)
        *cat=CELL_TYPE;
      else if(G_strstr(ebuf,".")!=NULL && sscanf(ebuf,"%f", &ftmp) ==1)
        *cat=FCELL_TYPE;
      else
        *cat=-1;
      while (!isspace (*buf) && !isnull(*buf))
        buf++;
        rewind (ptr);
        return 0;
      else
        buf++;
      break;
      (*dbls)++;
        buf++;
        rewind (ptr);
        return 0;
      else
        buf++;
      break;
        rewind (ptr);
        return 0;
      else
        buf++;
        (*strs)++;
        buf += err;
        buf++;
        rewind (ptr);
        return 0;
      else
        buf++;
      break;
  rewind (ptr);
  return 0;
int G_site_put_head (ptr, head)
  FILE *ptr;
  Site_head *head;
* Writes site_head struct.
  static char buf[128];
  if (head->name!=NULL)
    fprintf(ptr,"name|%s\n",head->name);
  if (head->desc!=NULL)
    fprintf(ptr,"desc|%s\n",head->desc);
  if (head->form!=NULL)
    fprintf(ptr,"form|%s\n",head->form);
  if (head->labels!=NULL)
    fprintf(ptr,"labels|%s\n",head->labels);
  /* time could be in (char *) stime, (DateTime *) time, both, or neither */
  if (head->stime!=NULL || head->time !=NULL)
    if (head->time != NULL) /* DateTime struct has precendence */
      datetime_format (head->time, buf);
      fprintf(ptr,"time|%s\n",buf);
    else if (head->stime != NULL) /* next check string */
      if (head->time==NULL)
         if ((head->time=(DateTime *) G_malloc(sizeof(DateTime)))==NULL)
           G_fatal_error("Memory error in writing timestamp");
      else if (datetime_scan (head->time, head->stime) < 0)
         G_warning("Illegal DateTime string");
      datetime_format (head->time, head->stime);
      fprintf(ptr,"time|%s\n",head->stime);
return 0;
int G_site_get_head (ptr, head)
  FILE *ptr;
  Site_head *head;
* Fills in site_head struct.
  int len;
    fprintf (stderr, "\nPROGRAMMER ERROR: G_site_get_head() must be called\n");
    return -2;
  head->name=NULL;
  head->desc=NULL;
  head->form=NULL;
  head->labels=NULL;
  head->stime=NULL;
  head->time=NULL;
  buf = sbuf;
    rewind (ptr);
    return EOF;
  /* assume header lines are always first records. allow for comments */
    len=strlen(buf);
    if (buf[len-1]=='\n')
         buf[len-1]=NULL;
    if (!strncmp(buf,"name|",5))
       buf+=5;
       head->name=G_strdup(buf);
    else if (!strncmp(buf,"desc|",5))
       buf+=5;
       head->desc=G_strdup(buf);
    else if (!strncmp(buf,"form|",5))
       buf+=5;
       head->form=G_strdup(buf);
    else if (!strncmp(buf,"labels|",7))
       buf+=7;
       head->labels=G_strdup(buf);
    else if (!strncmp(buf,"time|",5))
       buf+=5;
       head->stime=G_strdup(buf);
         G_fatal_error("Memory error in allocating timestamp");
       if (datetime_scan (head->time , head->stime)<0)
         G_warning(datetime_error_msg());
         head->time=NULL;
         head->stime=NULL;
    /* else is it a comment or some invalid header (not a decimal digit) */
      rewind (ptr);
      return EOF;
  rewind (ptr);
  return 0;
int G_site_in_region (site, region)
  Site *site;
  struct Cell_head *region;
/* returns 1 if site is contained within region, 0 otherwise */
/* northwest corner is in region, southeast corner is not. */
double e_ing;
double G_adjust_easting();
  e_ing = G_adjust_easting (site->east, region);
  if (e_ing >= region->west &&
      e_ing < region->east &&
      site->north <= region->north &&
      site->north > region->south)
    return 1;
  else
    return 0;
static int format_double (value, buf)
  double value;
  char *buf;
  int G_trim_decimal ();
  sprintf (buf, "%.8f", value);
  G_trim_decimal (buf);
  return 0;
int cleanse_string (buf)
  char *buf;
  char *stop, *p;
  p = buf;
   * get rid of any SPACEs at beginning while ( !isspace(*buf) && *buf !=
   * (char) NULL) buf++; if (*buf == (char) NULL) return -1;
  /* find where this string terminates */
  if (G_index (buf, DQUOTE) == (char) NULL) /* if no DQUOTEs, */
    stop = G_index (buf, SPACE);/* then SPACE separates */
    if (stop == (char *) NULL)
      return strlen (buf);
    else
      return (int) (stop - buf);
  else /* otherwise string is in DQUOTEs */
  { /* but we must skip over escaped */
    /* (BSLASHed) DQUOTEs */
    if (*p == DQUOTE)
      while (*p != (char) NULL) /* get rid of first DQUOTE */
        *p = *(p + 1);
        p++;
      p = buf;
      stop = G_index (p + 1, DQUOTE);
      while (*(stop - 1) == BSLASH)
        stop = G_index (++stop, DQUOTE);
  /* remove backslashes between buf and stop */
  while ((p = G_index (buf, BSLASH)) != (char *) NULL && p <= stop)
    if (*(p + 1) != (char) NULL && *(p + 1) == DQUOTE)
        *p = *(p + 1);
        p++;
      stop--;
char *next_att (buf)
  char *buf;
    buf++;
    return 0;
  else
    while (isspace (*(buf + 1)) && !isnull(*(buf + 1)))
      buf++;
  buf++;
  return buf;
int G_site_c_cmp (a, b)
  void *a, *b;
/* qsort() comparison function for sorting an array of
   site structures by category. */
  int result = 0; /* integer to be returned */
  double diff;
  switch((*(Site **)a)->cattype)
    case CELL_TYPE:
      diff = (double) (*(Site **) a)->ccat - (*(Site **) b)->ccat;
      break;
    case FCELL_TYPE:
      diff = (double) (*(Site **) a)->fcat - (*(Site **) b)->fcat;
      break;
    case DCELL_TYPE:
      diff = (double) (*(Site **) a)->dcat - (*(Site **) b)->dcat;
      break;
  if (diff < 0.0 )
    result = -1;
  else if (diff > 0.0)
    result = 1;
  return result;
int G_site_d_cmp (a, b)
  void *a, *b;
   site structures by first decimal attribute. */
  double diff;
  diff = (*(Site **) a)->dbl_att[0] - (*(Site **) b)->dbl_att[0];
  if (diff < 0.0 )
    result = -1;
    result = 1;
  return result;
int G_site_s_cmp (a, b)
  void *a, *b;
  return strcmp((*(char **)((*(Site **) a)->str_att)),
                (*(char **)((*(Site **) b)->str_att)));
* char *
* G_ask_sites_new(prompt, name))
* asks user to input name of a new site list file
* char *
* G_ask_sites_old(prompt, name)
* asks user to input name of an existing site list file
* char *
* G_ask_sites_any(prompt, name)
* asks user to input any site list name
* char *
* G_ask_sites_in_mapset(prompt, name)
* asks user to input name of an existing site list file in
* current mapset
* parms:
* char *prompt optional prompt for user
* char *name buffer to hold name of map found
* returns:
* char *pointer to a string with name of mapset
* where file was found, or NULL if not found
* note:
* rejects all names that begin with .
* FILE *
* G_sites_open_old (name, mapset)
* opens the existing site list file 'name' in the 'mapset'
* FILE *
* G_sites_open_new (name)
* opens a new site list file 'name' in the current mapset
* parms
* char *name map file name
* char *mapset mapset containing map "name"
char * G_find_sites (name, mapset)
  char *name, *mapset;
  return G_find_file ("site_lists", name, mapset);
char * G_find_sites2 (name, mapset)
  return G_find_file2 ("site_lists", name, mapset);
char * G_ask_sites_new (prompt, name)
  char *prompt, *name;
  char *G_ask_new ();
  return G_ask_new (prompt, name, "site_lists", "site list");
char * G_ask_sites_old (prompt, name)
  char *G_ask_old ();
  return G_ask_old (prompt, name, "site_lists", "site list");
char * G_ask_sites_any (prompt, name)
  char *G_ask_any ();
  return G_ask_any (prompt, name, "site_lists", "site list", 1);
char * G_ask_sites_in_mapset (prompt, name)
  char *G_ask_in_mapset ();
  return G_ask_in_mapset (prompt, name, "site_lists", "site list");
FILE * G_sites_open_old (name, mapset)
  return G_fopen_old ("site_lists", name, mapset);
FILE * G_sites_open_new (name)
  char *name;
  return G_fopen_new ("site_lists", name);
/* The following functions are obsolete. */
/* They are retained here only for backwards */
/* compatability while porting applications */
FILE *
G_fopen_sites_old (name, mapset)
    char *name;
    char *mapset;
FILE *
G_fopen_sites_new (name)
    char *name;
G_get_site (fd, east, north, desc)
    FILE *fd;
    double *east, *north;
    char **desc;
    char buf[400];
    char temp[400];
    static char *desc_ptr = NULL;
    fprintf(stderr,"WARNING: %s needs modified for the new Sites API\n",
            G_program_name() );
    if (desc_ptr != NULL)
        free (desc_ptr);
        desc_ptr = NULL;
    *temp = 0;
    while (fgets (buf, sizeof buf, fd))
        if (sscanf (buf, "point|%[^|]|%[^|]|%[^\n]", ebuf, nbuf, temp) >= 2
        || sscanf (buf, "%[^|]|%[^|]|%[^\n]", ebuf, nbuf, temp) >= 2)
            if (G_scan_northing (nbuf, north, G_projection())
            && G_scan_easting (ebuf, east, G_projection()))
                G_strip (temp);
                *desc = desc_ptr = G_store (temp);
                return 1;
    return -1;
G_put_site (fd, east, north, desc)
    FILE *fd;
    double east, north;
    char *desc;
    int fmt;
            G_program_name() );
/* fmt = G_projection(); */
    fmt = -1;
    G_format_northing (north, nbuf, fmt);
    G_format_easting (east, ebuf, fmt);
    fprintf (fd, "%s|%s|%s\n", ebuf, nbuf, desc?desc:"");
char * G_site_format (s, fs, id)
  Site *s;
  char *fs;
  int id;
/* sprintf analog to G_site_put with the addition of a field seperator fs
   and option of printing site attribute identifiers
  char xbuf[MAX_SITE_STRING];
  char *nfs, *buf;
  int fmt, i, j, k;
  buf=(char *)G_malloc(MAX_SITE_LEN*sizeof(char));
  nfs = (char *) ((fs == (char *) NULL) ? "|" : fs);
  sprintf (buf, "%s%s%s", ebuf, nfs, nbuf);
    sprintf (xbuf, "%s%s", nfs, nbuf);
  nfs= (fs == NULL) ? " " : fs;
  switch(s->cattype)
    case CELL_TYPE:
    sprintf (xbuf, "%s%s%d ", nfs, ((id==0) ? "" : "#"), (int)s->ccat);
    break;
    case FCELL_TYPE:
    case DCELL_TYPE:
    sprintf (xbuf, "%s%s%g ", nfs, ((id==0) ? "" : "#"), (float)s->fcat);
    break;
    sprintf (xbuf, "%s%s%s", nfs, ((id==0) ? "" : "%"), nbuf);
      j = k = 0;
            xbuf[k++] = BSLASH;
            xbuf[k++] = DQUOTE;
          else
          j++;
      else
        sprintf (xbuf, "%s%s\"%s\"", nfs, ((id==0) ? "" : "@"), s->str_att[i]);
      else
        sprintf (xbuf, "%s%s%s", nfs, ((id==0) ? "" : "@"), s->str_att[i]);
  return buf;
