Floating point code problems
Jazzman,
Try using a value greater than your number of rows on the command
line for v.to.rast ( rows=value ). I remember seeing that error
before and I think it worked OK when I used a big rows= value.
I don't remember seeing your problem with r.mask/r.reclass.
Bill
brown@gis.uiuc.edu
Bill
On Jan 14, 9:07am, Bill Brown wrote:
Subject: Re: Floating point code problems
Jazzman,
Bill
brown@gis.uiuc.edu
-- End of excerpt from Bill Brown
Thanks for the work around for v.to.rast, it seems to work fine. Hopefully
Baylor University will fix this problem in their GRASS 5.0 release.
For those of you who are using the floating point code version of GRASS, I
found the bug in r.reclass. Basically, the author was calling G_calloc with a
single argument (like a G_malloc call) instead of the two required by G_calloc.
The fix is as follows:
Line 28 of the file $GIS/src/raster/r.reclass/inter/maketable.c was changed
from
char_table = (char **) G_calloc((max-min+1) * sizeof(char *));
to
char_table = (char **) G_malloc((max-min+1) * sizeof(char *));
The Gmakefile in the r.reclass/inter/ directory actually makes the r.mask
command as well, so this fix takes care of both r.mask and r.reclass. This type
of problem produced an error on my system but it will not necessarily produce
errors on others. I recommend that floating point version users check to make
sure that this problem is fixed on their systems.
Thanks again Bill for your help. It is greatly appreciated.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
