format dwg?
This is a standard AutoCAD format which is not supported for import into GRASS.
You'll need to load it back on an AutoCAD system, and save it again as dxf
format. You'll then be able to use v.in.dxf
I have vector data in file with extension dwg? Does anyone know
about this format and conversion means to grass vector file?
TIA Peter pom@llnl.gov
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
