FORTRAN in UNIX
Please excuse me if you think this net is an appropriate place to post the
following question.
I am working on a fortran program under SPARCompiler environment. I want to
use a system call in which the parameter is a variable. For example:
      call ('uncompress filename')
where filename is variable whose value is assigned in a previous statement.
This doesn't work. However, it is ok when I replace variable filename with an
actual file name. Could anyone tell how to use system call in which the
Thank you very much.
Ye Qi
