I'm following the instructions of you, who say that I
must compile my owns programs ....
I find many troubles in this...if somebody can help me
I need to use v.db.rim and s.db.rim , I don't have a F77
compilator, and I 'm using f2c for translate the programs
from fortran to c... by first I must compile it (f2c)
and in this work i found that error "
"sysdep.c", line 66: warning: const is a keyword in ANSI C
"sysdep.c", line 66: syntax error before or at: char
"sysdep.c", line 428: syntax error before or at: void
"sysdep.c", line 428: parameter redeclared: const
"sysdep.c", line 430: undefined symbol: a
"sysdep.c", line 430: undefined symbol: b
"sysdep.c", line 518: cannot recover from previous errors
cc: acomp failed for sysdep.c
make: Fatal error: Command failed for target `sysdep.o'
*** Error code 1
can somebody help me???
can somebory send me v.db.rim and s.db.rim compiled???
