In article <9410042253.AA58878@halcon.dpi.udec.cl>, you write:
I wan to compile s.db.rim and v.db.rim
somebody has tell me that I must transponse it from fortran
to C with a F2c program....Does anybody made this before???
How I do this??? How I can compile these programs after this?My configuration:
Sun SPARC 20
SOlaris 3.3:)
thank's
Yes, I tried it, although I heard of people doing this without any problem
I didn't manage.
After you have translated all fortran-code with f2c you have normal C files
which you can compile with your normal c-compiler. I don't know if you can
use the set-up script from Grass directly, but I think you have to change some
things in this.
good luck,
Elwin
