Forwarded: Re: Displaying labels for r.contoured contours?
Content-Type: text
Content-Length: 00000001072
Date: ## 07/19/94 16:25 ##
Fred, A trick I use to get labels on things from dig_att files is to
copy the file in dig_att to site_lists directory (using awk as
described below to get it into proper sites format (eg.,
E|N|contour_label) then when I paint the file I tell it I want to
paint that new sites file and the when it asks if I want the site
labels as well, I say yes. I do this instead of making real label
files most the time because label files have a lot of stuff in them.
So here's the awk step I mentioned to make the sites file:
awk '{print S2"|"S3"|"S4}' SLOCATION/dig_att/contour_filename >
SLOCATION/site_lists/contour_labels
Okay, so their not the prettiest labels GRASS can make, but they're
adequate for most things.
Erin O'Doherty
Rocky Mtn Experiment Sta
Laramie WY
Previous comments:
Date: ## 07/19/94 04:10 ##
         DD.ID=internet(b)hacktic.nl(b)motte/
In Reply to Message :- 199407181142.VAA13807(a)aqua.civag.unimelb.EDU.AU
Content-Type: ForwardedIPmessage
Content-Length: 00000001355
Message-Version: 2
UA-Content-ID: <199407190809.AA29339(a)xs4all.hacktic.nl>
End-of-Header:
EMail-Version: 2
UA-Message-ID: <199407190809.AA29339(a)xs4all.hacktic.nl>
P2-Originator: internet!hacktic.nl!motte
End-of-Protocol:
Content-Type: text
Content-Length: 1086
Fred Watson writes:
I've being generating rainfall maps using s.surf.tps and the corresponding >
isohyets using r.contour.
Now, I want to be able to automatically label the isohyets with their >
respective rainfall values. Is there a way to do this under GRASS - or at least,
a way to make it easier than hand-labelling them? N.B: I notice that you can >
get the labels displayed by v.digit but thats not much use in the bigger picture
of things.
As you may have noticed, r.contour attaches attributes to the new vector map;
these are stored under SLOCATION/dig_att, so you have a file with the locations
of the labels. If you're prepared to spend some time on writing a script, you
could transfer these locations to a SLOCATION/paint/label file that you can
display with d.paint.labels. Hope this helps.
Philip Verhagen
S t i c h t i n g R A A P
Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
        1018 TV Amsterdam
       THE NETHERLANDS
phone: (31) 20 525 5835
fax:(31) 20 525 5834
e-mail:motte@hacktic.nl
