FP/ND for GRASS
Good that somebody finally takes this issue seriously! Here you have my
answers ("Lo bueno, si breve, dos veces bueno." F. de Quevedo, 1575).
1. What are the requirements for adequate implementation of floating point?
  - single vs. double precision: DOUBLE
  - should measurement precision metadata be attached to a raster, to
  truncate display values, and to be propagated to rasters derived from
  the original data set:IDEALLY
  - should an integer scaling be stored concurrently to benefit rapid
  display, or do the maintenance overhead and storage costs outweigh
  the value:NO
2. Is there an existing format standard (e.g. HDF) which should be adopted?
  What are it's advantages, disadvantages?:HDF would be great for portability (i.e. SpyGlass).
3. If floating-point support were to be implemented incrementally (utility
  by utility), which utilities should receive first priority for
  floating-point support?: r.mapcalc
4. Are there potential problems which may be anticipated to arise in the
  development of floating-point operation library functions which must
  remain compatible with the existing integer-based routines?
5. Null data bit maps seem a logical solution to provide distinction from
  true zeroes. Are there other techniques which should be considered?:
we could adopt NA and INF. The other functions should provide the optio of
just ignoring these values.
Agus
