I would also like to know what is fragstats ?
Nalneesh Gaur
From the Idrisi FAQ:
FRAGSTATS is a spatial pattern analysis program for quantify-
ing landscape structure. The raster version of the program
will read IDRISI image files (the vector version is for use
with ARC/INFO coverages). FRAGSTATS generates area metrics,
diversity metrics, and contagion and interspersion metrics.
A PC version of the program, along with documentation, is
available via anonymous FTP at FSL.ORST.EDU. FRAGSTATS can
be found in the PUB directory. Be sure to read the README.PS
file and the documentation in the MAN directory; installation
and operation instructions can be found in the FRAGSTATS.DOC
file in the raster and vector directories.
Further it should be noted that version 2.0 is out .
Randall Downer biosas@netcom.com
Rt 1 Box 391 919-968-1960 (FAX)
Pittsboro, NC 27312 919-968-0824 (VOICE)
