I have used the following code to allocate and free memory in one of the
r.le programs:
pt = (int *)G_calloc(100, sizeof(int));
for (i=0; i<100; i++)
free(pt[i]);
free(pt);
This works fine on Sun systems with a version of Unix System V, but
failsproduces the compiler message "incompatible integer/pointer combination"
on Apollo machines with bsd4.3. I forgot to mention that the declaration
is "int *pt;" before the above code. This problem was found by Lars
Schylberg.
Lars was able to fix the problem on the Apollo by replacing free(pt[i])
with free(&pt[i]). However, when I do this on my Sun I quickly run out
of memory, indicating that the memory is not being freed correctly.
I am simply a beginning programmer and can't find anything in the usual
C books about this. Anyone know a universal method for freeing memory
that will work with System V and bsd?
Bill Baker
bakerwl@corral.uwyo.edu
Univ. of Wyoming, Laramie
307-766-3311
BAKERWL (BAKERWL@corral.uwyo.edu) writes on 18 Jul 93:
r.le programs:
free(pt[i]);
free(pt);
My understanding of C is that you only need one call to
free for every malloc call. Therefore,
free(pt);
should be sufficient.
When higher dimension arrays are used, then you have to
call free more than once. For example, for an NxN array:
int **pt;
if ( (pt = (int **) malloc(N*sizeof(int *))) == NULL)
fprintf(stderr,"opps\n"), exit(-1);
for (i=0;i<N;++i)
if ( (pt[i] = (int *) malloc(N*sizeof(int))) == NULL)
for (i=0;i<N;++i)
free(pt[i]);
free(pt);
see the FAQ for comp.lang.c (available via anonymous ftp
from rtfm.mit.edu:pub/usenet/comp.lang.c).
BTW, is there a nice way to run lint with the Gmakefile
setup? I currently do something like this:
CC = lint
COMPILE_FLAGS =
--Darrell
