From Leonard Coop: Re: Forestry and Grass + scripts for models (fwd)
I forward this message to the
list as it seems that Leonard has problems to
post messages:
Agus
---------- Forwarded message ----------
Date: Tue, 26 Oct 1999 11:26:08 -0700
To: grass@cecer.army.mil, alobo@ija.csic.es
Subject: Re: Forestry and Grass + scripts for models
Agustin,
(note I cant post to grass list - It always seems to bounce, so you may
want
to forward this to the list)
Here is a snippet from a perl script (I didnt write it but I use it)
running GRASS showing how you can use perl files as standard i/o to
write to GRASS functions, in this case r.mapcalc:
    open RMAPCALC, "|r.mapcalc" or die "Can't launch r.mapcalc";
    # STEP 5: ADD CORRECTIONS
    print RMAPCALC "$corrname = ($basename * $rationame)/1000\n";
    # STEPS 6: FORCE NEGATIVES TO ZERO
    print RMAPCALC "$outname = max($corrname,0)\n";
    close RMAPCALC;
Thus once you know perl it is pretty obvious how to use grass like any
other
UNIX commands. I am still learning perl myself. We pass these scripts
into GRASS
with a "DOGRASS" script that sets up a GRASS shell environment and all
(similar to
GRASSLINKS, which is now done in perl I believe).
Len
Agustin Lobo wrote:
Well, I would not say that is "ideal", it is possible.
Actually, writing (i.e. population or metapopulation) models
in C (or C++) is far from ideal, as writing the code tends to
imply too much time devoted to "low level" (not a fair term, but an
usual one) programming and the resulting code uses to be
too obscure for others to read (often it's easier to
write your own program in C than reading it afterwards).
A closer-to-ideal situation would be having an script language, from
which you can call grass programs. I wrote a model
for gap dynamics in a neotropical forest using the c-shell
and calling grass functions. It was better (easier and faster) than
using C, but the code was almost as cryptic. Another problem
was the very limited power of the c-shell to manage
arrays (only 1-D) and to make computations (only integers), which
had to solve by using awk sometimes.
Now there are other script languages than could be better, i.e.,
like perl, does anybody have experience at integrating grass
commands within a perl script?
Finally, I explored the possibility of using Splus (R is now a
free alternative and mostly compatible) programs, as Splus (or R)
can issue OS commands. Therefore, it is possible, from within an
Splus program, run i.e. r.stats and read in the result into
an S array and make computations. But the communication is
through files.
In any case, I think that the (near) future of Grass should contemplate
the use of an scripting language for modeling. Is anybody at Baylor
working in this direction?
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
http://pangea.ija.csic.es/alobo
On Tue, 26 Oct 1999, Roy Sanderson wrote:
> Hello
> Colleagues of mine have been using GRASS for several years to model red and
> grey squirrel populations under different forest management regimes, and
> various control measures for grey squirrels. Grass is ideal for this type
> of work, especially since you can integrate your own process-based
> population models (we write ours in C) into the Grass environment.
> Roy
> At 04:32 pm 26/10/99 +0200, you wrote:
> >Hello (again)
> >I'm wondering if anybody of the grass-community has used Grass combined
> >with forestry --> modelling and planning etc.
> >sincerely Kjell-Olav
> Roy Sanderson
> Centre for Land Use and Water Resources Research
> Porter Building
> University of Newcastle
> Newcastle upon Tyne
> NE1 7RU
> United Kingdom
> Tel: +44 191 222 7789
> Fax: +44 191 222 6563
> r.a.sanderson@newcastle.ac.uk
> URL: http://www.cluwrr.ncl.ac.uk
Leonard Coop
Research Associate
Entomology Dept & Integrated Plant Protection Center
2046 Cordley
Oregon State University
Corvallis OR 97331-2907
