after invoking the Kriging module a system message appears:
'Are you sure you want to add the information in RHOME
to the registry?'. When Yes button is pressed, another
message appears: 'Cannot import RHOME. Error opening the file.
There may be a disk or file system error.'
I can't get rid of this (probably some .reg file is being executed), but
this is not the reason of...
Loading continues, but important buttons in the Kriging
dialog are disabled.
... as I've just found it works properly if valid data set is chosen. If no
'Numeric column' is present, buttons Plot/Refresh Variogram or Run are
disabled. My fault.
When entering the Kriging dialog when a vector map was
selected before this action via menu, I am getting
the following error and execution is stopped (no dialog appears)
v.krige input=isolines@honza
ERROR: Required parameter <column> was not set:
It seems to be a default behaviour when a vector map is selected. This
message is related to the previous one (if Kriging is performed on a vector
layer with no proper column data). But in such case maybe any Warning dialog
would be better than a message in the command line output...
I tried a better data set and although I got the correct variogram plot,
later I encountered ImageMagick! Exception:
import.exe: unable to open X server `' @ import.c/ImportImageCommand/367 [No
such file or directory].
Is it necessary to setup something else?
BTW, there is enclosed a screenshot in this e-mail with the current
appearance of the Krige command output tab. That horizontal thin white line
is a textbox with output messages... It could be improved a bit.
Jan
