(Fwd) Re: [GRASS-dev] Installation of GRASS on Fedora 9
Again to all.
I have overcome the problems with the patch in
http://bugs.gentoo.org/show_bug.cgi?id=217876
Now, the GRASS 6.2.3 is installed.
Thanks
Juan Diego
Juan Diego Giraldo Osorio
PhD Student
Departamento de Ingeniería Térmica y de Fluidos
Universidad Politécnica de Cartagena
+34 968 327 047
---------- Mensaje reenviado ----------
Para: Glynn Clements <glynn@gclements.plus.com>
Asunto: Re: [GRASS-dev] Installation of GRASS on Fedora 9
De: "Juan Diego Giraldo Osorio"<jdgiraldo@upct.es>
Fecha: Sat, 31 May 2008 17:09:21 +0200 (CEST)
Thanks
Juan Diego
Juan Diego Giraldo Osorio wrote:
> I have two pc: the firts with fedora 8, and the another one with
fedora
> 9. In the fedora 9 pc I have installed GRASS 6.2.3 in the fedora 8
pc,
> without problems (except by the gdal install circular problem which
is
> explained in http://www.kyngchaos.com/wiki/macosx:build:gdal). Now,
> GRASS is running in the fedora 8 pc without problems.
> In the fedora 9 pc I have had problems with the gdal-1.4.1 install.
The
> error report is the next:
Problems with GDAL should be reported to the GDAL developers, either
on the mailing list, IRC channel, or bug tracker. Details are at:
  http://www.gdal.org/
PhD Student
+34 968 327 047
