We are having a problem with the g.help after we successfully (?) installed
GRASS 4.0 on our SiliconGraphics IRIS-4D.
By simply typing g.help on the command lind, we cannot use RETURN key to
move the (*) to a topic/word. However, this can be done by using Ctl-J key
instead. The worst thing is after we exit the g.help facility we still get
the RETURN key function lost and it is equivalent to Ctl-M which results in
the subsequent GRASS command unaccessible.
Do you have any experience of solving this kind of problem or any suggestion
on what installation procedure we might be wrong??
Thanks in advance.
Changyi Sun USU Forest Resources, Logan UT 84322-5215
Internet: csun@zircon.nr.usu.edu
slt25@cc.usu.edu
