Changyi Sun writes:
We are having a problem with the g.help after we successfully (?) installed
GRASS 4.0 on our SiliconGraphics IRIS-4D.
This is an old message that was posted in response to the same problem
several months ago:
From: hoffmann@urzdfn.kartographie.tu-dresden.dbp.de
Message-Id: <930108105358*/S=hoffmann/OU=urzdfn/OU=kartographie/PRMD=TU-DRESDEN/ADMD=DBP/C=DE/@MHS>
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Precedence: Bulk
Sender: lists-owner@moon.cecer.army.mil.
Reply-To: grassu-list@moon.cecer.army.mil.
Precedence: Bulk
In-Reply-To: <199301080924.AA21771@max.cecer.army.mil>
Subject: (was without subject line: about G.HELP)
Status: R
Try it to use with ^j after command instead of RETURN.
We got the same effect, but on a TEK-88(U/TekV).
Example:
GRASS> G.HELP^J (control/j)
It should be an effect of unix compiling... our gurus said.
FH-TUD
