>mccauley@ecn.purdue.eduwrites on Wed Jun 30 17:14:58 1993
>> (btw, does anyone else think that "g.manual" a little long
for a
>> command name?
>> --Darrell
>Not just too long, I like g.man better because it sounds unix.
A lot of
>students I teach are novices to GRASS and UNIX. I think they
learn faster
>if things are more consistent. So how about g.rm, g.cp instead
of
>g.remove, g.copy, etc.? It would really be great if the
horrible
>``option=name1,name2'' command line arguments would replaced
for
>unix syntax.
>Raymond Venneker - Inst. of Earth Sc., Free University
Amsterdam
Good idea! If you use csh or tcsh, add the lines:
echo "alias g.man g.manual" >> $cshrc
echo "alias g.rm g.remove" >> $cshrc
echo "alias g.cp g.copy" >> $cshrc
to the file $GISBASE/etc/GIS.sh in the csh|tcsh alternative to the case
"$sh" statement. Is that clear as mud? Here's what I mean:
case "$sh" in
csh|tcsh)
HOME=$LOCATION
export HOME
cshrc=$HOME/.cshrc
tcshrc=$HOME/.tcshrc
rm -f $cshrc $tcshrc
echo "set home = $home" > $cshrc
echo "set history = 30 noclobber ignoreeof" >> $cshrc
echo "set prompt = '\\" >> $cshrc
echo "Mapset <${MAPSET}> in Location <${LOCATION_NAME}> \\" >>
$cshrc
echo "GRASS 4.1 > '" >> $cshrc
echo 'set BOGUS=``;unset BOGUS' >> $cshrc
if [ -r $home/.grass.cshrc ]
then
cat $home/.grass.cshrc >> $cshrc
fi
if [ -r $home/.cshrc ]
then
grep '^ *set *mail *= *' $home/.cshrc >> $cshrc
fi
if [ -r $home/.tcshrc ]
then
grep '^ *set *mail *= *' $home/.tcshrc >> $cshrc
fi
if [ -r $home/.login ]
then
grep '^ *set *mail *= *' $home/.login >> $cshrc
fi
echo "set path = ( $PATH ) " | sed 's/ /'g >> $cshrc
# Added by M. Camann 930630
cp $cshrc $tcshrc
$ETC/run $SHELL
HOME=$home
export HOME
This will give you g.man, g.cp, and g.rm, though the options
still do not adhere to unix conventions. You _could_ write
shell scripts instead of simply using aliases and pass their
arguments according to unix conventions without too much
difficulty. Needless to say, you need write permission in
$GISBASE/etc/GIS.sh in order to add the lines above.
Of course, if you use some other shell, you'll have to modify
the command accordingly.
Mike Camann
camann@dial.pick.uga.edu
