g.region error
Shawn,
Just a guess, but probably whatever program you are trying to
run is resetting the region to an illegal value. If you're
running d.3d, I think I remember a bug when trying to run it
with a lat-lon dataset using 90 N and -90 S ... try using
d.zoom or g.region to set N & S at least 1 ns_res in from the
poles. If you're running some other program, tell us what it
is and send the output from g.region -p.
P.S. I'm cc'ing you on this because when you tried to subscribe,
you sent your SUB to grassu-list instead of grassu-request.
To subscribe to one of the lists:
Send a mail message to either
        grassu-request@max.cecer.army.mil
          or
        grassp-request@max.cecer.army.mil
with "subscribe [yourname]" in the subject or body. Replace [yourname]
with your real name. The list will add the e-mail address that it finds in
the "From:" field of your letter.
- Bill B.
