g.region
Michael,
We have a very complicated system. Our system was originally set
up such that the location was in ALBERS coordinates and we were only
allowed to make mapsets under this area.. Our system administrator
did not believe that people wanted to work in UTMS and was very security
minded. In other words people were not allowed to make new locations for
any new projects that they wanted to do so we had to improvise by putting
our UTM mapsets down under this location. Things have improved since he
is no longer in control of the system. However old habits die hard.
Linda Bragg
It isn't my assumption. It is the way GRASS was originally
designed. LOCATIONs are in one projection - all data share the
same coordinate system. This is a fundamental design in GRASS and
very expensive to change.
Of course, you can trick GRASS, by editting the WIND file in your
mapset (and all the cellhd files as well) and just change the zone.
As long as the WIND file and the cellhd files havew the same zone
GRASS will be happy. But you will run into problems if you try to
do anything with a map that is in a different zone.
I agree that this is a hassle. Perhaps if you could change
locations without leaving GRASS, would that be a reasonable
compromise?
|Mr. Shapiro
|you make the assumption that everyone works in only one area in a mapset.
|if you are working with data all over the US sometimes it makes sense to
|be able to just edit the zone if you are working in UTMS and just change
|where you are in order to be able to work with the data in one location
|without continuously getting in and out of grass.
|Linda Bragg
|This way you can keep several mapsets in one location.
Michael Shapiro U.S. Army CERL
email: shapiro@amber.cecer.army.mil Office of GRASS Integration
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
