g.setproj
Can someone explain how g.setproj works. According to the man page, it
should prompt for the projection. In practice howver, it seems to read
the proj from DEFAULT_WIND. The problem I'm finding is that the only
valid proj: values are:
      0:(xy)
      1:(utm)
      2:(state plane)
      3:(ll)
and g.setproj doesn't like anything else. So how do I get nifty
projections like aea,lcc,merc,tmerc? Note this is the same list that
comes up for me when making a new location. Shouldn't that include all these
projections?
Yes it should. This is a severe weakness in GRASS.
Tim
... which was largely rectified in GRASS4.1 using proj:value "99" ("other")
which allows a _large_ selection of projections. I use Lambert Conformal
Conic and Albers Equal Area regularly. I suggest you update too.
____
__________________________________________________________________
Dr Simon Cox __ L
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009, Australia ( \ Cooperative
      Phone +61 9 389 8421 + ___ / Research
      Fax +61 9 389 1906 L~~' "\__/ Centre
s.cox@dem.csiro.au 7
      0:(xy)
      1:(utm)
      2:(state plane)
      3:(ll)
projections?
Tim
.... which was largely rectified in GRASS4.1 using proj:value "99" ("other")
I have 4.1 but I don't (generally) do vectors. Is there an easy way
in GRASS to convert raster data between different projections? Really
I'm just curious as I would like to be able to overlay images from
different sources with different projections. I'm thinking of adding
this functionality into Khoros v2, but would be interested in knowing
if it already exists in GRASS or elsewhere.
Tim -- "If only the world were flat!"
