Did anyone ever figure out what's going on with G_window_overlap?
I did a bad thing and recompiled a GRASS lib (I was trying to add -g
so that I could figure out some things with xdbx).
I'm trying to compile something:
cc -o s.voronoi OBJ.sun4/[bunch of dot-oh files] \
/home/soils/g/aggrass/grass4.1/src/libes/LIB.sun4/libgis.a \
/home/soils/g/aggrass/grass4.1/src/libes/LIB.sun4/libvect.a \
/home/soils/g/aggrass/grass4.1/src/libes/LIB.sun4/libdig2.a \
/home/soils/g/aggrass/grass4.1/src/libes/LIB.sun4/libdig_atts.a \
/home/soils/g/aggrass/grass4.1/src/libes/LIB.sun4/libdisplay.a -lm
ld: Undefined symbol
_G_window_overlap
So, I check the library
% ar t /home/soils/g/aggrass/grass4.1/src/libes/LIB.sun4/libgis.a \
| grep overlap
wind_overlap.o
seems to be there. Now I check the source:
% grep G_window_overlap \
/home/soils/g/aggrass/grass4.1/src/libes/gis/wind_overlap.c
G_window_overlap (window, N, S, E, W)
yep, this function *should* be in libgis.a
So, what's going on here?!? I'm recompiled several times (undoing
my -g addition), ran ranlib, etc, all to no avail.
Checking the archives, I see that people have run into this problem
before. Was the solution ever identified and applied?
I have Update 3 installed. This is on a sun4 (4.1.1) using Sun's ld.
--Darrell
Date: Tue, 6 Oct 1992 11:29:18 MDT
From: ront@niwot.CFNR.ColoState.EDU (Ronald E. Thomas)
Subject: SCS tools
cc -s -o /files/grass4/etc/bin/contrib/cmd/v.report OBJ.sun386/main.o OBJ.sun386
/format.o OBJ.sun386/header.o OBJ.sun386/label.o OBJ.sun386/parse.o OBJ.sun386/
prt_report.o OBJ.sun386/do_v_stats.o OBJ.sun386/prt_unit.o OBJ.sun386/
perimeter.o OBJ.sun386/report.o OBJ.sun386/stats.o OBJ.sun386/sums.o
/data/grass.scripts/src/libes/LIB.sun386/libgis.a /data/grass.scripts/src/libes
/LIB.sun386/libvect.a /data/grass.scripts/src/libes/LIB.sun386/libdig2.a -lm
G_window_overlap
Subject: 4.1 on alpha
Date: Mon, 25 Oct 1993 13:50:48 (EDT)
I'm porting GRASS 4.1 to DEC alpha hardware using gcc for my compiler.
Has anyone else done this?
Specifically, at a first glance it looks like the functions G_window_overlap
and G_window_percentage_overlap are defined in src/libes/gis/wind_overlap.c
but are not declared extern anywhere -- a bunch of vector routines
that call them can't find them. Should they be declared in gisdefs.h?
Thanks for any help -- gcc is a lot stricter than the old DEC compilers,
and before I wade through all the information it spits out, I'd like to
know if someone has already done it.
From: Martin Ameskamp <ma@informatik.uni-kiel.d400.de>
Subject: Grass function declarations
I have extracted all the function declarations for the GIS, Raster,
Vector and Display libraries and collected them in one file
(most of them, anyway - might have missed one or two) because
I'm using GRASS from C++ (gcc-2.3.3 to be exact) and C++ is even more
strict about prototypes than gcc.
