I’m working on a project that combines Geoserver & Geofence server with openid (keycloak) authentication. The authentication part works just fine. However the Geofence server does not apply any rule for a found role:
Welcome to GeoServer 3.1.0
Updating GeoServer Credentials ...
USING USERS XML ORIGINAL: /usr/local/tomcat/webapps/geoserver/data/security/usergroup/default/users.xml
USING ROLES XML ORIGINAL: /usr/local/tomcat/webapps/geoserver/data/security/role/default/roles.xml
SETTING USERS XML: /opt/geoserver_data//security/usergroup/default/users.xml
SETTING ROLES XML: . /opt/geoserver_data//security/role/default/roles.xml
Successfully replaced /opt/geoserver_data//security/usergroup/default/users.xml
Successfully replaced /opt/geoserver_data//security/role/default/roles.xml
... DONE updating GeoServer Credentials ...
20-Oct-2026 10:56:47.898 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/11.0.27
20-Oct-2026 10:56:47.903 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Oct 6 2026 18:12:07 UTC
20-Oct-2026 10:56:47.903 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 11.0.27.0
20-Oct-2026 10:56:47.904 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Linux
20-Oct-2026 10:56:47.904 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 5.14.0-570.142.1.el9_6.x86_64
20-Oct-2026 10:56:47.904 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
20-Oct-2026 10:56:47.904 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /opt/java/openjdk
20-Oct-2026 10:56:47.904 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 25.0.4.1+1-LTS
20-Oct-2026 10:56:47.904 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Eclipse Adoptium
20-Oct-2026 10:56:47.905 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /usr/local/tomcat
20-Oct-2026 10:56:47.905 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /usr/local/tomcat
20-Oct-2026 10:56:47.931 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/usr/local/tomcat/conf/logging.properties
20-Oct-2026 10:56:47.931 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0027
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang.reflect=ALL-UNNAMED
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util.concurrent=ALL-UNNAMED
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --enable-native-access=ALL-UNNAMED
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseContainerSupport
20-Oct-2026 10:56:47.932 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:MaxRAMPercentage=80.0
20-Oct-2026 10:56:47.933 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:InitialRAMPercentage=25.0
20-Oct-2026 10:56:47.933 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
20-Oct-2026 10:56:47.933 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8
20-Oct-2026 10:56:47.933 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djavax.servlet.request.encoding=UTF-8
20-Oct-2026 10:56:47.933 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djavax.servlet.response.encoding=UTF-8
20-Oct-2026 10:56:47.933 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -D-XX:SoftRefLRUPolicyMSPerMB=36000
20-Oct-2026 10:56:47.933 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xbootclasspath/a:/usr/local/tomcat/lib/marlin.jar
20-Oct-2026 10:56:47.933 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dsun.java2d.renderer=sun.java2d.marlin.DMarlinRenderingEngine
20-Oct-2026 10:56:47.933 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.geotools.coverage.jaiext.enabled=true
20-Oct-2026 10:56:47.934 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/usr/local/tomcat
20-Oct-2026 10:56:47.934 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/usr/local/tomcat
20-Oct-2026 10:56:47.934 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/usr/local/tomcat/temp
20-Oct-2026 10:56:47.938 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded Apache Tomcat Native library [2.0.16] using APR version [1.7.6].
20-Oct-2026 10:56:47.946 INFO [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized [OpenSSL 3.5.5 27 Jan 2026]
20-Oct-2026 10:56:48.300 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
20-Oct-2026 10:56:48.350 INFO [main] org.apache.catalina.startup.Catalina.load Server initialization in [665] milliseconds
20-Oct-2026 10:56:48.385 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
20-Oct-2026 10:56:48.385 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/11.0.27]
20-Oct-2026 10:56:48.389 SEVERE [main] org.apache.catalina.startup.HostConfig.beforeStart Unable to create directory for deployment: [/usr/local/tomcat/conf/Catalina/localhost]
20-Oct-2026 10:56:48.394 INFO [main] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [/usr/local/tomcat/webapps/geoserver]
26 Oct 09:37:05 WARN [geoserver.logging] - The logging location can be set using GEOSERVER_LOG_LOCATION property
26 Oct 09:37:23 DEBUG [geoserver.geofence] - Getting access limits for Layer testlayer + containers
26 Oct 09:37:23 DEBUG [geoserver.geofence] - IP source address found in OWSRequest
26 Oct 09:37:23 DEBUG [geofence.util] - Authorizations found for user testuser@example.com: [ROLE_GEOSERVERUSER,ROLE_AUTHENTICATED]
26 Oct 09:37:23 DEBUG [geofence.util] - Authorizations allowed: []
I have a rule for the role ROLE_GEOSERVERUSER in place. Why doesn’t it match?
What am I missing?
/Theo
