Geographic boundaries in GRASS raster/vector files
On Mon, 10 Apr 2000, Bill Brown - staff wrote:
To be precise, it should be:
    north = max(y) + n-s res / 2.0
    south = min(y) - n-s res / 2.0
    west = min(x) - e-w res / 2.0
    east = max(x) + e-w res / 2.0
if you are certain that the data profiles in your original data were used
as boundaries. Otherwise either your resolution or rows/cols won't match
up.
Bill,
  Good point -- when the original data are in a raster format. Almost all of
our data (and the .e00/.shp/.mi(f,d)) are vector format. The corners are the
corners of the coverage area, not the center of the corner cells.
  I appreciate the reminder of the difference when translating points to the
GRASS edges.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
