[GeoNetwork-devel] 2.8 build broken...
2.8 build does not seem to compile.
It seem it was caused by commit 5f7fe250850fba4bb41a59275ea3c46273f0a702 -
1116: GetRecords hardcoded prefixes in TypeNames check
It looks like the xml folder was not uploaded - not sure if this should be
the same as what is in the master?
Look like it cannot find
    import org.fao.geonet.util.xml.NamespaceUtils
in
    web/src/main/java/org/fao/geonet/kernel/csw/services/GetRecords.java
View this message in context: http://osgeo-org.1560.n6.nabble.com/2-8-build-broken-tp5012578.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
you’re right, my mistake. I’ll commit the missing directory in 2.8.x also. If you are very hurried you can take the same from master, it’s identical.
Thanks !
Heikki Doeleman
in
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
GeoNetwork-devel mailing list
