[GeoNetwork-devel] 2.8.x nightly build broken
The 2.8.x nightly build jar file seems to have failed since Feb 13. The war
file seem ok. Can someone look into this where there is time....
Thanks.
View this message in context: http://osgeo-org.1560.n6.nabble.com/2-8-x-nightly-build-broken-tp5039579.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Ian
I’ll check later today to fix this.
Jose García
On Mon, Mar 11, 2013 at 1:55 PM, ianwallen <ianwallen@anonymised.com.22…> wrote:
file seem ok. Can someone look into this where there is time…
Thanks.
Symantec Endpoint Protection 12 positioned as A LEADER in The Forrester
Wave™: Endpoint Security, Q1 2013 and “remains a good choice” in the
endpoint security space. For insight on selecting the right partner to
tackle endpoint security challenges, access the full report.
http://p.sf.net/sfu/symantec-dev2dev
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Ian
The nightly build for 2.8 is fine now. It’s rebuilding now also trunk and old 2.6.
Jose García
On Mon, Mar 11, 2013 at 1:57 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Ian
Jose García
Thanks.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
