[GeoNetwork-devel] abusing the spatial index
Hi
I have been abusing the spatial index to selectively store snippets of some records and the using it in another application and linking back to the actual record in geonetwork.
Previously I would only write my records (non-harvested) and non-template records to the shapefile.
With the recent optimisations being committed to trunk, I cant work out where to put these changes in.
Can anyone give me a few pointers on where it could go?
Terry Rankine
Hi Terry,
I think what you are after for shapefiles has moved to createShapefileDatastore in src/org/fao/geonet/GeoNetwork.java - if you are using PostGIS then you might also need to modify the database table created for the spatialindex in gast/setup/sql/create-db-postgis.sql
Simon
________________________________________
From: Terry.Rankine@anonymised.com [Terry.Rankine@anonymised.com]
Sent: Tuesday, 13 April 2010 11:37 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: [ExternalEmail] [GeoNetwork-devel] abusing the spatial index
Hi
Terry Rankine
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
GeoNetwork-devel mailing list
