Hi Francois,
Thanks a lot.
Now, the ISO19119 schema is included and I can show and edit a service metadata. Just to add the translation of new terms (in regard to the 19139) and optimize the template.
Do you like to integrate in GN 2.1 ?
Pierre LAGARDE
BRGM - STI/DIR
3 avenue Claude Guillemin BP 39009 - 45060 Orléans cedex 2 - France
Tel : +33 (0)2 38 64 30 05
Portable: 06 10 79 29 73
-----Message d'origine-----
De : François Prunayre [mailto:fx.prunayre@anonymised.com]
Envoyé : mardi 5 juin 2007 14:24
À : 'Jeroen Ticheler'; Lagarde Pierre
Cc : geonetwork-devel@lists.sourceforge.net
Objet : RE: [GeoNetwork-devel] Add a new schema
Hi Pierre, you should have a look to metadata-utils.xsl and add :
<xsl:include href="metadata-iso19119.xsl"/>
<!-- ISO 19119 -->
<xsl:when test="$schema='iso19119'">
<xsl:call-template name="iso19119Brief"/>
</xsl:when>
This is called by the search-result.xsl. The brief template should be in your metadata-iso19119.xsl.
Ciao. Francois
De : geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de Jeroen Ticheler Envoyé : lundi 4 juin 2007 14:54 À : Lagarde Pierre Cc : geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] Add a new schema
Hi Pierre,
Did you create an XSL to present the metadata? In the Brief template, you have to make the match to the correct title field. The brief template creates a normalized view of all the different metadata formats.
Ciao,
Jeroen
On 4 Jun 2007, at 8:59 AM, Lagarde Pierre wrote:
I succeeded in adding a 19119 schema in GN beta 1 but I would like to
indicate the "title" Xpath localisation in order to display this
information in result page (currently, the metadata file displays
without any title) or in the selectbox when you create a new metadata.Where have I to do this config ?
Pierre
This SF.net email is sponsored by DB2 Express Download DB2 Express C - the FREE version of DB2 express and take control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
GeoNetwork-devel mailing list
Pensez à l'environnement avant d'imprimer ce message
Think Environment before printing
Le contenu de ce mél et de ses pièces jointes est destiné à l'usage exclusif du (des) destinataire(s) désigné(s)
comme tel(s).
En cas de réception par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
L'absence de virus a été vérifiée à l'émission, il convient néanmoins de s'assurer de l'absence de
contamination à sa réception.
The contents of this email and any attachments areconfidential. They are intended for the named recipient(s)
only.
If you have received this email in error please notifythe system manager or the sender immediately and do not
disclose the contents to anyone or make copies.
eSafe scanned this email for viruses, vandals and malicious content.
