I've created a new stylesheet to register SOS services, i tested it and it's
working.
I can import a SOS GetCapabilities document in "Metadata insert", because i
added a new option on the StyleSheet options.
I've already added SOS as a new type of services in
loc/en/xml/harvesting.xml wxstype element, but when i try to harvest a SOS,
it doesn't work. I think it's because Geonetwork is calling the
OGCWxSGetCapabilities-to-19119.xsl instead of the new one i created,
OGCSOSGetCapabilities-to-19119.xsl.
How do i change that, so when the "Type of OGC webservice" is SOS, the
harvester knows that he has to use the OGCSOSGetCapabilities-to-19119.xsl?
working.
Great !
You've 2 options :
* modify the Harvester (line 263) in order to use your stylesheet if
type is SOS instead of the default one.
* or merge your stylesheet with the default one.
The first option is probably easier and better.
I made a ticket [1] for enhancement in order to split the XSL for each
type of OGC services.
You could also add you SOS XSL to the patch and I could integrate that later.
The second option doesn't work. I tried to make the modifications on the
OGCWxSGetCapabilities-to-19119.xsl, but it can't process the SOS
GetCapabilities well, that's why i made a new one.
The first option looks good to me. But i have installed Geonetwork 2.4.3.
How do i make modifications on my version? Compile the source code that is
on the installation folder? How do i make a new project on eclipse, using
that source code?
that source code?
Check the developper doc you have on the installation. Make sure you
have the src folder installed. Basically you need to run ant on the
GeoNetwork folder to compile the application. The online developper
manual [1] is for 2.6.x series.
I run the command "ant" on the folder "installer" but i get this error:
BUILD FAILED
C:\Users\vmag.USIC_INESCPORTO\Documents\geonetwork\installer\build.xml:146:
The
following error occurred while executing this line:
C:\Users\vmag.USIC_INESCPORTO\Documents\geonetwork\docs\build.xml:70:
Compile fa
iled; see the compiler error output for details.
Before i got this error, i had others saying that were missing some folders
on the "docs" folder, so i copied the missing folders to the "docs" folder,
and solved the problem. But now i can't solve this one. Any clue?
BUILD FAILED
The
Compile fa
I can't run ant on the docs folder, because there isn't any build.xml on
that folder. The one that appears on my error, it's because i copied the
build.xml to the docs folder.
The first error that appears when i run ant on the installer folder is:
BUILD FAILED
C:\geonetwork\installer\build.xml:104: Warning: Could not find file
C:\geonetwor
k\docs\readme.html to copy.
So i copied the docs folder from C:\geonetwork\web\geonetwork\ to
C:\geonetwork\ and tried to run ant again, but got an error again:
BUILD FAILED
C:\geonetwork\installer\build.xml:146: The following error occurred while
execut
ing this line:
java.io.FileNotFoundException: C:\geonetwork\docs\build.xml (The system
cannot f
ind the file specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:106)
at
org.apache.tools.ant.helper.ProjectHelper2.parse(ProjectHelper2.java:
268)
at
177)
at
org.apache.tools.ant.ProjectHelper.configureProject(ProjectHelper.jav
a:82)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:393)
at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at
org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.jav
a:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:390)
at org.apache.tools.ant.Target.performTasks(Target.java:411)
at
org.apache.tools.ant.Project.executeSortedTargets(Project.java:1397)
at org.apache.tools.ant.Project.executeTarget(Project.java:1366)
at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExe
cutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1249)
at org.apache.tools.ant.Main.runBuild(Main.java:801)
at org.apache.tools.ant.Main.startAnt(Main.java:218)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:280)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:109)
If i comment that line, i get this error:
BUILD FAILED
C:\geonetwork\installer\build.xml:148: Basedir C:\geonetwork\geoserver does
not
exist
BUILD FAILED
C:\geonetwor
BUILD FAILED
execut
ing this line:
cannot f
at
268)
at
177)
at
a:82)
at
at
java:39)
at
sorImpl.java:25)
at
a:106)
at
at
cutor.java:41)
BUILD FAILED
not
exist
