[GeoNetwork-devel] add metadata schema ebRIM
Hello,
I have geonetwork version 2.10.1.
There is a functionality called "Add a metadata schema/profile" into
Administration.
I want to know if it is posible to add the metadata schema ebRIM with this
functionality, or this functionality only applies to add new labels for
ISO19115/19139 schema.
Best regards,
Ana.
View this message in context: http://osgeo-org.1560.x6.nabble.com/add-metadata-schema-ebRIM-tp5176496.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Ana
You can add new schemas, not really required to be based on ISO19115/19139. See in https://github.com/geonetwork/schema-plugins a list of available schema profiles that can be installed.
For the one you comment, unless you already have develop it, it’s not available.
Jose García
On Thu, Dec 4, 2014 at 5:11 PM, Ana <ammpalomares@anonymised.com> wrote:
Hello,
There is a functionality called “Add a metadata schema/profile” into
Administration.
Best regards,
Ana.
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Thanks Jose,
I hoped it would not touch the source code and directories of geonetwork, I
thought it was automatic and it accepted any schema.
View this message in context: http://osgeo-org.1560.x6.nabble.com/add-metadata-schema-ebRIM-tp5176496p5176506.html
Hi Ana
Requires development, specially if not based on any of the available schemas.
Here you can find documentation about the schema profile development: http://geonetwork-opensource.org/manuals/trunk/eng/developer/schemaPlugins/index.html
Jose García
On Thu, Dec 4, 2014 at 5:59 PM, Ana <ammpalomares@anonymised.com039…> wrote:
Thanks Jose,
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
