Hi, I am a geotools/geoserver developer and want to contribute some code to geonetwork. My biggest customer is IBM minded and uses DB2. Since we have to participate in the EU INSPIRE project we decided to use a geonetwork/geoserver combination.
One of my geotools modules is the DB2 datastore. Within the last 12 months I downloaded some versions of geonetwork and always had to adapt geonetwork to work with DB2. I am little bit tired on this procedure
1)
The first questions is if the community has some interest to integrate DB2 support the same way as it has been done for Oracle, mysql, postgres. I would maintain the DB2 stuff in the future.
I did an svn checkout from trunk and developed DB2Panel.java for the connection parameters. So far so good. I am unsure about the following.
2)
There are some scripts data-db-xxx.sql and create-db-xxx.sql. I created data-db-db2.sql and create-db-db2.sql manually. Is this correct or are you using some tool to generate these batch files ?
3)
There is a file
gast/setup/database.druid
What is the usage of this file ?
Christian
This message was sent using IMP, the Internet Messaging Program.
