[GeoNetwork-devel] Adding MCP 2.0 to geonetworks 2.10
I have downloaded the master version of the schema plugin at github https://github.com/geonetwork/schema-plugins
Tried to install the iso19139.mcp-2.0 using the Administration interface but with no success – so I copied the folder directly into /web/geonetwork/WEB-INF/data/config/schema_plugins
I then used the administration interface to load the iso19139.mcp-2.0 templates. This was done without error.
When I tried to create a new record however using one of the templates I get:
XPathException : Template iso19139.mcp-2.0-javascript has not been defined
I can see that the template name iso19139.mcp-2.0-javascript is defined in iso19139.mcp-2.0/present/metadata-iso19139.mcp-2.0.xsl
Can someone please help?
Thanks.
Kind Regards.
