[GeoNetwork-devel] AGROVOC
Has anyone successfully integrated the AGROVOC Thesaurus (Agricultural Vocabulary) with GeoNetwork 2.1? Ideally I would like a search for “Corn” in my GeoNetwork keyword search and return all records containing the keyword “Maize” (for example). My understanding was that AGROVOC allows this type of synonymous (as well as broader / narrower) search. Unfortunately I’ve been getting a “null pointer exception” error every time I try and load the Thesaurus. Any thoughts?
Grant McKenzie
GIS Developer
Enterprise Management Solutions
CH2M Hill
Seattle WA
Direct: 425.233.3271
Mobile: 425.233.4562
grant.mckenzie@anonymised.com
I have already try to integrate the Agrovoc thesaurus.
But the rdf file is more than 59Mo. If i remember well that cause an
exception because the file is too big.
Make a check in your log.
Anyway the release 2.1 doesn't manage the narrower and broader word. In the
2.1 the thesaurus is a simple list of keyword.
I don't know if the 2.2 manage this part.
Best regards,
Fabien Bachraty
"Corn" in my GeoNetwork keyword search and return all records containing
the keyword "Maize" (for example). My understanding was that AGROVOC
Unfortunately I've been getting a "null pointer exception" error every
Grant McKenzie
GIS Developer
CH2M Hill
Seattle WA
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-devel mailing list
View this message in context: http://www.nabble.com/AGROVOC-tp16260874s18419p16269303.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Quoting FBachraty <Fabien.Bachraty@anonymised.com>:
Maybe try to not load the multilingual rdf file. Works fine for me even with the
big one. Problem with huge thesaurus, it's that the rdf file is loaded at
startup, if you use too big thesaurus that could slow down the GeoNetwork
startup process. So if you're using Agrovoc in only one language maybe filter
the language you want before loading.
No it will not. An option could be to change the lucene index process to add
narrower, broader, related term to the index when indexing metadata, another
option is to add those terms at search time ...
Ciao. Francois
I want to have a precision , where is located the AGROVOC rdf file with
just one language , I have just find the big file on this folder
ftp://ftp.fao.org/gi/gil/gilws/aims/kos/agrovoc_formats/skos/
Thanks a lot
Benjamin
Francois-Xavier Prunayre-2 wrote:
with the
filter
the
add
another
Ciao. Francois
View this message in context: http://www.nabble.com/AGROVOC-tp16260874s18419p16468069.html
Hi list, another issue which could occur with the Agrovoc thesaurus import is
in the latest release of Agrovoc (Date : 080422).
There is two non UTF-8 characters.
Here is line number in the SKOS file format.
diff ag_skos_080422.rdf
ag_skos_080422ok.rdf
Line number 29860 d 29859
< <skos:altLabel xml:lang="fa">مواد آرسنيكدار</skos:altLabel>
Line number 450448 d 450446
< <skos:altLabel xml:lang="fa">فوزاريوم اكسياسپوروم
فازئولي</skos:altLabel>
Remove these lines (if you don't need it) to load the file without
exception.
HTH. Francois
PS: it should be fixed in later Agrovoc release.
View this message in context: http://www.nabble.com/AGROVOC-tp16260874p17334991.html
