[GeoNetwork-devel] An exceptionin the test phase of Build from svn version
after resolve the last troubles to Build phase (adding a mirror to maven). It is now capable to build all modules, but after it give an exception in the test phase (i suppose) .
2011-06-11 15:19:22,671 ERROR [jeeves.engine] - Raised exception during destroy
2011-06-11 15:19:22,672 ERROR [jeeves.engine] - Exception : java.lang.NullPointerException
2011-06-11 15:19:22,672 ERROR [jeeves.engine] - Message : null
2011-06-11 15:19:22,674 ERROR [jeeves.engine] - Stack : java.lang.NullPointerException
         at org.jzkit.z3950.server.Z3950Listener.shutdown(Z3950Listener.java:99)
         at org.fao.geonet.services.util.z3950.Server.end(Server.java:68)
         at org.fao.geonet.Geonetwork.stop(Geonetwork.java:650)
         at
Looking at report I understand the new internal DB is become H2 instead of McKoy.
So, perhaps, I miss some extra setting I don't know ?
I add the full report here:
[INFO] GeoNetwork opensource ............................. SUCCESS [2.877s]
[INFO] Caching xslt module ............................... SUCCESS [9.698s]
[INFO] Jeeves modules .................................... SUCCESS [12.928s]
[INFO] Oaipmh modules .................................... SUCCESS [2.749s]
[INFO] ArcSDE module (dummy-api) ......................... SUCCESS [3.230s]
[INFO] GeoNetwork Web module ............................. SUCCESS [1:31.511s]
[INFO] GeoServer module .................................. SUCCESS [14.529s]
[INFO] Gast module ....................................... SUCCESS [41.262s]
[INFO] GeoNetwork Integration Tests ...................... SUCCESS [1:23.001s]
[INFO] BUILD SUCCESS
[INFO] Total time: 4:23.351s
[INFO] Finished at: Sat Jun 11 15:19:19 CEST 2011
[INFO] Final Memory: 117M/272M
2011-06-11 15:19:22,568 INFO [jeeves.engine] - === Stopping system ========================================
2011-06-11 15:19:22,568 INFO [jeeves.engine] - Stopping schedule manager...
2011-06-11 15:19:22,568 INFO [jeeves.engine] - Stopping handlers...
2011-06-11 15:19:22,568 INFO [jeeves.apphand] - Stopping geonetwork...
2011-06-11 15:19:22,568 INFO [jeeves.apphand] - - search...
2011-06-11 15:19:22,569 INFO [jeeves.apphand] - - Z39.50...
2011-06-11 15:19:22,569 INFO [jeeves.apphand] - - ThreadPool ...
2011-06-11 15:19:22,569 INFO [jeeves.apphand] - - MetadataNotifier ...
         at jeeves.server.JeevesEngine.stopHandlers(JeevesEngine.java:656)
         at jeeves.server.JeevesEngine.destroy(JeevesEngine.java:634)
         at jeeves.server.sources.http.JeevesServlet.destroy(JeevesServlet.java:88)
         at org.eclipse.jetty.servlet.ServletHolder.destroyInstance(ServletHolder.java:310)
         at org.eclipse.jetty.servlet.ServletHolder.doStop(ServletHolder.java:284)
         at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:80)
         at org.eclipse.jetty.servlet.ServletHandler.doStop(ServletHandler.java:196)
         at org.eclipse.jetty.server.handler.HandlerWrapper.doStop(HandlerWrapper.java:108)
         at org.eclipse.jetty.security.SecurityHandler.doStop(SecurityHandler.java:350)
         at org.eclipse.jetty.security.ConstraintSecurityHandler.doStop(ConstraintSecurityHandler.java:237)
         at org.eclipse.jetty.server.session.SessionHandler.doStop(SessionHandler.java:125)
         at org.eclipse.jetty.server.handler.ContextHandler.doStop(ContextHandler.java:675)
         at org.eclipse.jetty.servlet.ServletContextHandler.doStop(ServletContextHandler.java:143)
         at org.eclipse.jetty.webapp.WebAppContext.doStop(WebAppContext.java:458)
         at org.mortbay.jetty.plugin.JettyWebAppContext.doStop(JettyWebAppContext.java:188)
         at org.eclipse.jetty.server.handler.HandlerCollection.doStop(HandlerCollection.java:247)
         at org.eclipse.jetty.server.Server.doStop(Server.java:319)
         at org.mortbay.jetty.plugin.Monitor.run(Monitor.java:102)
org.h2.jdbc.JdbcSQLException: Database is already closed (to disable automatic closing at VM shutdown, add ";DB_CLOSE_ON_EXIT=FALSE" to the db URL) [90121-152]
         at org.h2.message.DbException.getJdbcSQLException(DbException.java:327)
         at org.h2.message.DbException.get(DbException.java:167)
         at org.h2.message.DbException.get(DbException.java:144)
         at org.h2.message.DbException.get(DbException.java:133)
         at org.h2.jdbc.JdbcConnection.checkClosed(JdbcConnection.java:1370)
         at org.h2.jdbc.JdbcConnection.checkClosed(JdbcConnection.java:1345)
         at org.h2.jdbc.JdbcConnection.createStatement(JdbcConnection.java:168)
         at org.h2.server.web.DbStarter.contextDestroyed(DbStarter.java:73)
         at org.eclipse.jetty.server.handler.ContextHandler.doStop(ContextHandler.java:683)
2011-06-11 15:19:22.717:INFO::stopped o.m.j.p.JettyWebAppContext{/geonetwork,file:/home/archivio/tomcat/software/geonetwork/trunk/web/target/geonetwork/},/home/archivio/tomcat/software/geonetwork/trunk/web/target/geonetwork.war
tomcat@anonymised.com:~/software/geonetwork/trunk$
Andrea Peri
