[GeoNetwork-devel] another issue with saxon ?
Using official GN 2.4, i’m getting today, from time to time, the following error.
Sure, i’m cusotmizing a bit my instance of geonetwork, but, i believe, in no way that could generate this kind of error…
Any idea ?
The only way i found to bypass the error is to restart tomcat (reloading the page, and even reloading the web app doesn’t suffice !)
Jean
Error log :
208594 [http-8080-1] INFO jeeves.request - ==========================================================
208594 [http-8080-1] INFO jeeves.request - HTML Request (from 127.0.0.1) : /gn24_projet1/srv/fr/main.home
208594 [http-8080-1] DEBUG jeeves.request - Method : GET
208594 [http-8080-1] DEBUG jeeves.request - Content type : null
208594 [http-8080-1] DEBUG jeeves.request - Accept : text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8
208594 [http-8080-1] DEBUG jeeves.request - Session id is DDDE5318CCA536B296BB88C352AA489E
208594 [http-8080-1] INFO jeeves.service - Dispatching : main.home
208594 [http-8080-1] DEBUG jeeves.service - → no input parameters
208610 [http-8080-1] INFO jeeves.service - → dispatching to output for : main.home
WARNING: transformerfactory doesnt like saxon attributes!
208875 [http-8080-1] INFO jeeves.service - → transforming with stylesheet : C:\softs\apache-tomcat-6.0.16\webapps\gn24_projet1/xsl/main-page.xsl
ID systÞme inconnu; Ligne #22; Colonne #71; Impossible de trouver la fonction : tokenize
ID systÞme inconnu; Ligne #22; Colonne #71; jeton de fonction introuvable.
(Emplacement inconnu de l’erreur)java.lang.NullPointerException
209032 [http-8080-1] ERROR jeeves.service - → exception during transformation for : main.home
209032 [http-8080-1] ERROR jeeves.service - → (C) stylesheet : C:\softs\apache-tomcat-6.0.16\webapps\gn24_projet1/xsl/main-page.
xsl
209032 [http-8080-1] ERROR jeeves.service - → (C) message : null
209032 [http-8080-1] ERROR jeeves.service - → (C) exception : NullPointerException
209032 [http-8080-1] DEBUG jeeves.service - Raised exception while executing service
fr
main.home
209032 [http-8080-1] INFO jeeves.service - → dispatching to error for : main.home
209047 [http-8080-1] INFO jeeves.service - → transforming with stylesheet : C:\softs\apache-tomcat-6.0.16\webapps\gn24_projet1/xsl/error.xsl
209094 [http-8080-1] INFO jeeves.service - → end error transformation for : main.home
209094 [http-8080-1] INFO jeeves.service - → error ended for : main.home
N’imprimez ce message qu’en cas de nécessité. Soyons éco-responsables !
Donnez une nouvelle dimension à vos données…
I G E
Jean POMMIER
Directeur Associé
TIC - Webmapping 3D
Port : +33 6 09 23 21 36
Skype : igejean
Information Géographique et Environnement
12 rue Arnaud Vidal
31000 Toulouse
France
Tel : +33 5 61 86 81 49
Fax : +33 5 61 86 09 23
Mail : contact@anonymised.com
Site web : www.ige.fr
L’actualité d’IGE sur RSS : http://www.ige.fr/actualites/rss.php
Localisez IGE dans WorldWind : worldwind://goto/world=Earth&lat=43.55519&lon=1.38256&alt=190&dir=26.7&tilt=60.3
Note that unlike any other error, it completely freezes the geonetwork instance !
2009/7/29 Jean Pommier (IGE) <jean.pommier@anonymised.com558…>
Any idea ?
Jean
Error log :
xsl
fr
main.home
I G E
Jean POMMIER
Directeur Associé
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
Hi Jean,
The log message:
usually means that your GeoNetwork is somehow NOT using saxon because the attempt to set saxon attributes on the transformer factory didn't work, so this sounds like your GeoNetwork instance is still using xalan (same for the message about the tokenize function).
We use the services API to tell GeoNetwork to use saxon as the transformer factory (so as not to interfere with geoserver) - so you need the file in meta information (web/geonetwork/WEB-INF/classes/META-INF/services/javax.xml.transform.TransformerFactory) with the caching transformer factory name in it (same for intermap).
Simon
PS: your email subject says 'another' issue with saxon - were there any others?
2009/7/29 Jean Pommier (IGE) <jean.pommier@anonymised.com <mailto:jean.pommier@anonymised.com>>
    Using official GN 2.4, i'm getting today, from time to time, the
    following error.
    Sure, i'm cusotmizing a bit my instance of geonetwork, but, i
    believe, in no way that could generate this kind of error...
    Any idea ?
    (reloading the page, and even reloading the web app doesn't suffice !)
    Jean
    Error log :
    text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
    208594 [http-8080-1] DEBUG jeeves.service - -> no input parameters
    208610 [http-8080-1] INFO jeeves.service - -> dispatching to
    208875 [http-8080-1] INFO jeeves.service - -> transforming
    with stylesheet :
    C:\softs\apache-tomcat-6.0.16\webapps\gn24_projet1\/xsl/main-page.xsl
    introuvable.
    (Emplacement inconnu de l'erreur)java.lang.NullPointerException
    209032 [http-8080-1] ERROR jeeves.service - -> exception
    209032 [http-8080-1] ERROR jeeves.service - -> (C) stylesheet
    : C:\softs\apache-tomcat-6.0.16\webapps\gn24_projet1\/xsl/main-page.
    xsl
    209032 [http-8080-1] ERROR jeeves.service - -> (C) message : null
    209032 [http-8080-1] ERROR jeeves.service - -> (C) exception : NullPointerException
    <error id="error">
      <message />
      <class>NullPointerException</class>
      <stack>
        <at class="jeeves.utils.Xml" file="Xml.java" line="243"
    method="transform" />
        <at class="jeeves.utils.Xml" file="Xml.java" line="204"
        <at class="jeeves.server.dispatchers.ServiceManager"
    file="ServiceManager.java" line="678" method="dispatchOutput" />
    file="ServiceManager.java" line="383" method="dispatch" />
        <at class="jeeves.server.JeevesEngine"
    file="JeevesEngine.java" line="621" method="dispatch" />
        <at class="jeeves.server.sources.http.JeevesServlet"
    file="JeevesServlet.java" line="174" method="execute" />
    file="JeevesServlet.java" line="89" method="doGet" />
        <at class="javax.servlet.http.HttpServlet"
    file="HttpServlet.java" line="690" method="service" />
    file="HttpServlet.java" line="803" method="service" />
        <at class="org.apache.catalina.core.ApplicationFilterChain"
    file="ApplicationFilterChain.java" line="290"
    method="internalDoFilter"
      </stack>
      <request>
        <language>fr</language>
        <service>main.home</service>
      </request>
      <response />
    </error>
    209032 [http-8080-1] INFO jeeves.service - -> dispatching to
    209047 [http-8080-1] INFO jeeves.service - -> transforming
    with stylesheet :
    C:\softs\apache-tomcat-6.0.16\webapps\gn24_projet1\/xsl/error.xsl
    209094 [http-8080-1] INFO jeeves.service - -> end error
    209094 [http-8080-1] INFO jeeves.service - -> error ended for
    : main.home
            N'imprimez ce message qu'en cas de nécessité. Soyons
            éco-responsables !
            I G E
            Jean POMMIER
            *Directeur Associé*
            TIC - Webmapping 3D
            Skype : igejean
            12 rue Arnaud Vidal
            31000 Toulouse
            France
            Mail : contact@anonymised.com <mailto:contact@anonymised.com>
            Site web : www.ige.fr <http://wwww.ige.fr>
            *L'actualité d'IGE sur RSS :
            *http://www.ige.fr/actualites/rss.php
            *Localisez IGE dans WorldWind :
            *worldwind://goto/world=Earth&lat=43.55519&lon=1.38256&alt=190&dir=26.7&tilt=60.3
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what's new with Crystal Reports now. Best Open Source Mac Front-Ends 2024
GeoNetwork-devel mailing list
geonetwork-devel List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hi Simon,
Thanks for the answer.
I did not change the services/javax.xml.transform.TransformerFactory from its original value when it started occurring.
However, i thought it was something similar, so i tried also with the ‘no-caching’ value, net.sf.saxon.TransformerFactoryImpl, but it still occurred.
Looks like it is somewhat related with some part of javascript code i imported from geocat (geographic filter one, i believe). I’ll try a bit later to find what happens. Right now, i have to let it apart.
Il i find, i’ll post the info, of course !
Jean
PS : well, when i wrote ‘another’ issue, i just thought of the “html ‘version=1.0’” that caused pbs in some thesaurus-*.xsl… nothing new ! ;o)
2009/7/30 Simon Pigot <Simon.Pigot@anonymised.com>
Hi Jean,
The log message:
usually means that your GeoNetwork is somehow NOT using saxon because the attempt to set saxon attributes on the transformer factory didn’t work, so this sounds like your GeoNetwork instance is still using xalan (same for the message about the tokenize function).
Simon
PS: your email subject says ‘another’ issue with saxon - were there any others?
2009/7/29 Jean Pommier (IGE) <jean.pommier@anonymised.com mailto:[jean.pommier@anonymised.com](mailto:jean.pommier@anonymised.com)>
following error.
Any idea ?
Jean
Error log :
with stylesheet :
introuvable.
xsl
fr
main.home
with stylesheet :
: main.home
éco-responsables !
I G E
Jean POMMIER
Directeur Associé
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
Mail : contact@anonymised.com mailto:[contact@anonymised.com](mailto:contact@anonymised.com58...)
*L’actualité d’IGE sur RSS :
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what’s new with Crystal Reports now. http://p.sf.net/sfu/bobj-july
