Reading the CSW specifications, there's mention of (optional) support for joins in queries. Now, there's just one incomplete example in the document (in fact, the actual query is lacking ) and I can't think of many examples of queries that require a join. The obvious one I can come up with is a join between contact person and metadata record, something like "find all records describing data on 'soils' with organization name 'FAO'".
Am I missing something obvious here? Anyone has some good examples of queries a user might expect to see answered by a catalog that require these type of queries? Are they just a few that you would reasonably expect, or should such functionality be implemented in a generic manner?
Um I remember wanting to do a join; I forget which metadata model it was (either ebRIM or ISO profile); but I wanted
to figure out which wfs was serving a particular feature type; and then join it up with a styles for that feature type.
Basically; what styles work with this data; it was a hard query because I needed to do a join; and I also needed to
go up the feature type heirarchy asking the question again and again; until I reached "Feature".
I often make queries (or make assumptions) to figure out what services publish out the same information (ie same data published via WMS and WFS); does that require a join?
Are they just a few that you would reasonably expect, or should such functionality be implemented in a generic manner?Hoping for some good feedback here.
Not sure if the above counts as good feedback
Jody
