In response to Amit's below message on July 7, 2008, I am running into
some errors using the plugin, hopefully this is the correct place to
discuss them.
I just installed the plugin in an ArcCatalog 9.2 sp3 install on Win XP.
I am hitting a GeoNetwork 2.2 instance.
When I try to upload metadata for a dataset with the tool, I get four
alert boxes with the following messages.
13
Type mismatch
createMEF
53
File not found
SendFile
Failed to login or upload a file.
Import failed!
Any suggestions on where to start debugging?
David.
_______________________
Hello all. First, I should introduce myself as this is my first mail to
the list. I've been working with Jeroen at FAO for the past few weeks
on some tools for sharing data with GeoNetwork. I'm also working on a
metadata crawler application that will look for appriate data for
GeoNetwork inclusion and create appropriate metadata for MEF creation.
I've just published the first tool which is a ArcCatalog plugin which
allows for upload of data to GeoNetwork within the ArcCatalog
environment.
You can install the software from this link:
http://sourceforge.net/project/showfiles.php?group_id=85997&package_id=8
9219&release_id=611302
***** Please note: this is a beta release, do not use this in a 'live'
environment ******
The plugin requires GeoNetwork v2.2 or above in order for some of the
functionality to work properly. The installer includes a readme file
with basic instructions on how to use tool. If you run into any issues,
please let me know!
And the code is on SVN here:
http://arcmaptools.svn.sourceforge.net/viewvc/arcmaptools/trunk/arcmapto
ols/AC2GeoNetwork/
Amit
