[GeoNetwork-devel] ArcSDE thumbnail
Part of the things we have been looking at using Geonetwork for at
work has involved harvesting from ArcSDE. One of the things we noticed
was missing was a way to harvest the thumbnails that are sometimes
stored in the metadata harvested from Arc. It turns out that Arc uses
a method to convert these thumbnails to images for display within
ArcCatalog. This method is available through a jar file which ships
with Arc.
Using this, I have written a class that sits inside
org.fao.geonet.arcgis which can harvest a thumbnail from an XML
element, store it in a temp file, and then load that temp file as a
thumbnail for a metadata element. As a part of this, I needed to
extend the dummy ArcSDE module.
Would this be a useful thing to add to the Geonetwork codebase? If so,
how should I go about getting it verified and uploaded?
Elgar Storm
Hi Elgar,
I would be interested in using this code if you are willing to share.
To submit it for inclusion into trunk you can use the bug tracking system,
Trac at
/http://trac.osgeo.org/geonetwork//
To post a ticket you will first need a OSGeo id. This can be obtained at:
/https://www2.osgeo.org/cgi-bin/ldap_create_user.py/.
When you create the ticket you can attach your code to it.
Byron
View this message in context: http://osgeo-org.1560.n6.nabble.com/ArcSDE-thumbnail-tp4799284p4801494.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
