I am using Geonetwork v2.1. One day, I met a problem. That is I can not log
in my Geonetwork web application. I tried to restart my Tomcat server but
nothing happened.
Can you tell me how to solve it?
Here is my log:
2007-11-27 15:30:46,267 INFO [jeeves.request] -
2007-11-27 15:30:46,268 INFO [jeeves.request] - HTML Request (from
127.0.0.1) : /hcmgisportal/srv/vi/user.login
2007-11-27 15:30:46,268 DEBUG [jeeves.request] - Method : POST
2007-11-27 15:30:46,268 DEBUG [jeeves.request] - Content type :
application/x-www-form-urlencoded
2007-11-27 15:30:46,268 DEBUG [jeeves.request] - Accept :
text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
2007-11-27 15:30:46,270 INFO [jeeves.service] - Dispatching : user.login
2007-11-27 15:30:46,270 DEBUG [jeeves.service] - -> parameters are :
<request>
<password>admin</password>
<username>admin</username>
</request>
2007-11-27 15:30:46,270 ERROR [jeeves.service] - Exception when executing
service
2007-11-27 15:30:46,271 ERROR [jeeves.service] - (C) Exc :
java.lang.NullPointerException
2007-11-27 15:30:46,272 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
<message />
<class>NullPointerException</class>
<stack>
<at class="org.fao.geonet.services.login.Login" file="Login.java"
line="67" method="exec" />
<at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="238" method="execService" />
file="ServiceInfo.java" line="141" method="execServices" />
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="372" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="600" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="163" method="execute" />
file="JeevesServlet.java" line="98" method="doPost" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="710" method="service" />
line="803" method="service" />
<at class="org.apache.catalina.core.ApplicationFilterChain"
file="ApplicationFilterChain.java" line="290" method="internalDoFilter" />
</stack>
<request>
<language>vi</language>
<service>user.login</service>
</request>
</error>
2007-11-27 15:30:46,272 INFO [jeeves.service] - -> dispatching to error
for : user.login
2007-11-27 15:30:46,419 ERROR [jeeves.service] - Exception executing gui
service : java.lang.NullPointerException
2007-11-27 15:30:46,419 ERROR [jeeves.service] - (C) Stack trace is :
at org.fao.geonet.guiservices.util.Env.exec(Env.java:53)
at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75)
at
jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119)
at
jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:103)
at
jeeves.server.dispatchers.ServiceManager.dispatchError(ServiceManager.java:668)
at
jeeves.server.dispatchers.ServiceManager.handleError(ServiceManager.java:460)
at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:405)
at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:600)
at
jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:163)
at
jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:98)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:263)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:584)
at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
2007-11-27 15:30:46,423 INFO [jeeves.service] - -> transforming with
stylesheet :
/home/phamvubinh/SVN_STORAGE/HCMGisPortal/trunk/source/web/hcmgisportal/xsl/error.xsl
2007-11-27 15:30:46,833 INFO [jeeves.service] - -> end error
transformation for : user.login
2007-11-27 15:30:46,834 INFO [jeeves.service] - -> error ended for :
user.login
View this message in context: http://www.nabble.com/Ask-about-Login-problem...!!-tf4880410s18419.html#a13966758
Sent from the geonetwork-devel mailing list archive at Nabble.com.
