Hello friends,I'm newbie in geonetwork, can someone help me to change
language in geonetwork with adding new language choice in banner? I'm very
thank you about your help.=^D
View this message in context: http://www.nabble.com/ask%3Alanguage-change---tp18806725p18806725.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Hello,
if you want to add a new language to geonetwork banner, you have to
edit banner.xsl in web/geonetwork/xsl and edit strings.xml files in each
language directory (en, fr, cn,..) in web/geonetwork/loc.
Bye
Michele Beretta
Hello Berreta,i'm still have problem in homepage of my geonetwork when i
change the language. The combo box for region on below of minimap in the
left side site is gone. When i use English language it's display again like
Africa, Australia, etc.But when i change to my language it' gone. What i
must do?Thanks for your help.
View this message in context: http://www.nabble.com/ask%3Alanguage-change---tp18806725p18854386.html
hi,
do you mean the region select box has actually disappeared, or is it just empty ? If empty it’s probably because you’ll also need to put support for your targeted language in to the database, in addition to localizing the strings.xml files.
I will send you an SQL file that adds Dutch language to the database, as an example so you can see which tables are affected.
Let me know how things go,
regards,
Heikki Doeleman
On Wed, Aug 6, 2008 at 9:00 AM, ai <ai_mahathir@anonymised.com> wrote:
Hello Berreta,i’m still have problem in homepage of my geonetwork when i
left side site is gone. When i use English language it’s display again like
Africa, Australia, etc.But when i change to my language it’ gone. What i
must do?Thanks for your help.View this message in context: http://www.nabble.com/ask%3Alanguage-change—tp18806725p18854386.html
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
GeoNetwork-devel mailing list
