[GeoNetwork-devel] BlueNet MEST 1.1 with Marine Community, ANZLIC and defence profiles [SEC=UNCLASSIFIED]
I have problem with installation process of BlueNet Mest 1.1
I tried following link and extracted jar file.
http://anzlicmet.bluenet.utas.edu.au
Before starting installation script I deleted existing geonetwork 2.1 tables.
And ran installation script. After finishing the installation process I found
only few tables in my database, some of them are missing (While installing
database it displayed an error, I couldn't copy that it displayed big xml
file in one line I pressed 'OK', then it come up with another window saying
"continue" I pressed 'yes' and the process continued). I retried installation
to recreate the database with default values. Same happened.
Is there someone to help me on this?
Thanks in advance
Thank you
Nalina Vanguru
D & D Toolset
ISB
Geoscience Australia
(w) 62499524
Hi Nalina,
In the documentation that came with the download of the BlueNet MEST it is mentioned that problems and discussions should be referred to the anzlicmet-l group which you can find out how to subscribe to by sending an email as follows:
anzlicmet-l@anonymised.com
with bugs and issues reported to the trac site http://anzlicmet.bluenet.utas.edu.au
Please do not post queries about the BlueNet MEST/ANZLIC MET to the geonetwork-devel users group or to Jeroen Ticheler as any problems with this software are the responsibility of BlueNet and not the wider geonetwork developers group.
I'll give you a call to help you resolve your install problems.
Simon Pigot
BlueNet
University of Tasmania, Hobart, Australia, 7001
Phone: +61 3 6226 1975
Simon.Pigot@anonymised.com
Nalina.Vanguru@anonymised.com wrote:
Thanks in advance
Thank you
Nalina Vanguru
D & D Toolset
ISB
(w) 62499524
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
GeoNetwork-devel mailing list
geonetwork-devel List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Correction - the email address for subscription info on the list to discuss the anzlicmet/bluenet mest is:
anzlicmet-l-request@anonymised.com
Apologies,
Simon
