[GeoNetwork-devel] BlueNet MEST - Components
I would like to run the BlueNet version of Geonetwork to experience the Component function.
On the Solid Earth and Environmental GRID Web site, I found a link to the svn code...
|svn co https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/sandbox/BlueNetMEST BlueNetMEST
I checked out this code and compiled successfully.
At startup the following exception is displayed in the jetty log...
11:14:17.486 INFO [main] org.mortbay.log.LogImpl.add(LogImpl.java:109) >16> added org.mortbay.log.OutputStreamLogSink@anonymised.com
11:14:17.471 INFO [main] org.mortbay.util.FileResource.<clinit>(FileResource.java:60) >11> Checking Resource aliases
11:14:17.735 INFO [main] org.mortbay.http.HttpServer.doStart(HttpServer.java:729) >10> Version Jetty/5.1.5rc2
11:14:18.000 INFO [main] org.mortbay.util.Container.start(Container.java:74) >15> Started org.mortbay.jetty.servlet.WebApplicationHandler@anonymised.com
11:14:18.026 INFO [main] org.mortbay.util.Container.start(Container.java:74) >11> Started WebApplicationContext[/GCMDFinder,/GCMDFinder]
11:14:18.146 INFO [main] org.mortbay.util.Container.start(Container.java:74) >15> Started org.mortbay.jetty.servlet.WebApplicationHandler@anonymised.com
java.lang.reflect.InvocationTargetException
    at org.mortbay.start.Main.invokeMain(Main.java:151)
    at org.mortbay.start.Main.start(Main.java:476)
    at org.mortbay.start.Main.main(Main.java:94)
Caused by: javax.xml.transform.TransformerFactoryConfigurationError: Provider de.fzi.dbs.xml.transform.CachingTransformerFactory not found
    at javax.xml.transform.TransformerFactory.newInstance(TransformerFactory.java:108)
    at jeeves.server.JeevesEngine.init(JeevesEngine.java:122)
    at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:66)
    at javax.servlet.GenericServlet.init(GenericServlet.java:168)
    at org.mortbay.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:383)
    at org.mortbay.jetty.servlet.ServletHolder.start(ServletHolder.java:243)
    at org.mortbay.jetty.servlet.ServletHandler.initializeServlets(ServletHandler.java:446)
    at org.mortbay.jetty.servlet.WebApplicationHandler.initializeServlets(WebApplicationHandler.java:321)
    at org.mortbay.jetty.servlet.WebApplicationContext.doStart(WebApplicationContext.java:511)
    at org.mortbay.util.Container.start(Container.java:72)
    at org.mortbay.http.HttpServer.doStart(HttpServer.java:753)
    at org.mortbay.jetty.Server.main(Server.java:439)
    ... 7 more
The xalan.jar implementation is present in the lib folder. Could this be a configuration error of some sort...?
Tips would be appreciated.
Marty.
Hi Marty,
Build the installer (ant installer) and then run the installer jar that is created in dist/BlueNetMEST-1.*/
BlueNetMEST was going to be set up as a WAR - check the archives for more info.
Simon
_____________________
Sent: Wednesday, 11 November 2009 7:48 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] BlueNet MEST - Components
Component function.
the svn code...
|svn co
BlueNetMEST
Jetty/5.1.5rc2
    at
    at
    at
    at
    at
    at
    at
    ... 7 more
Marty.
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-devel mailing list
geonetwork-devel List Signup and Options
