[GeoNetwork-devel] Broken image on metadata.
I now know why I see only the admin in the user.list view: there is a sql query “select groupId as is from userGroups where id = xxx, but when the jeeves Dbms class converts the result set to a tree, it takes the column name not the column label. The next block of code attempts to read out a datum called ‘id’ – which returns null as there isn’t one. Thus the groups check fails and the active session user (admin!) isn’t shown the user queried from the database.
Just.
Sent: 06 July 2010 13:04
To: geonetwork-devel@lists.sourceforge.net
Subject: Broken image on metadata.
I have taken a clean pull of the repository, built with Maven, and then imported the various projects into Eclipse. Changed config to run over mysql, and launch in Tomcat and I have a working build of GeoNetwork! Hurrah!
Would a shopping list of tasks to do this be of any use to anyone? I couldn’t find any documentation for building now that Maven is being used.
I see two problems though:
  1. A broken image when viewing metadata. Is this related to the FIXME at line 101 in metadata-show? If so, should I worry or will it be addressed
  2. When I query the users as admin, I only see admin. No idea what causes this.
I would try searching for reported bugs, but the geonetwork-opensource server is down L
Thanks
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
