[GeoNetwork-devel] bug in 2.6.4
mef.import.ui in metadata-insert-form doesn’t exist, it should be mef.import
Hi Zhao
I just checked in GitHub the tag 2.6.4, mef.import.ui is defined in config.xml and the permissions set in user-profiles.xml.
Please check if using old 2.6.4 tag code. This tag was recreated recently in GitHub as was not correct.
Jose García
On Tue, Oct 23, 2012 at 9:48 AM, Zhao Zhengjian <zhengjian.zhao@anonymised.com> wrote:
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
