Hi Andrea,
I added it to the front end since the back end implementation has always been there. I haven't tested it thoroughly though because it always used to be there. Did anything change in that part of the search engine?
It should restrict the result set by only showing records part of the group. Maybe this changed now that you modified the ownership model?
What's the conflicting part, I didn't understand what you wrote.
Ciao,
Jeroen
On Oct 8, 2007, at 6:40 PM, Andrea Carboni wrote:
Hi Jeroen,
the search by group (in advanced search) simply does not work and the used
element (/request/group) conflicts with the normal search engine. I don't know
who added this. Probably Emanuele did only the front-end and the back end
is still unfinished.Furthermore, its semantic is not clear: search by group owner or simply for
metadata that belong to that group?I suggest to hide that option or, at least, to define its semantic.
