[GeoNetwork-devel] Bug on quick category search
Hi all, On the home page, if you select a category, you get all the
result for the selected category. Then if you select the "sort by"
option, you'll sort on all records (all categories) because we're in
simplesearch mode.
An option to solve that issue could be to add the category to the simple
search criteria. For example in the options section we could add the
list of category.
And then a categorySearch should resetSimpleSearch before run.
I you agree with that I'll open a ticket on that and fixed it.
Cheers. Francois
