[GeoNetwork-devel] Bug with Remote Search??
has anyone solved Enris bug with remote search?
I have the same problem (and log4j.1.2.5.jar in WEB-INF/lib folder).
Thanks
Stefan
  Do you think there is a bug with remote search? I find the problem exists with every site
using version 2.0.2. As an example, Please check http://vam.wfp.org/vamsie/srv/en/main.home
with following conditions:
  use remote search, set title:Tsunami, and select all servers in the list, and submit. You
will get following result:
  Aggregate Results matching search criteria : 33
  and a list of blank records, if you click them, it complains "The 'id' parameter is missing
or empty" .
  Enri
